Go Back   OC3D Forums > [OC3D] Cooling Forum > Air Cooling
Thread Tools Display Modes
  #1
Old 10-11-17, 11:44 PM
VibeOnPC VibeOnPC is offline
Newbie
Best fans for airflow/low temp ?
Looking into getting some fans for my phanteks eclipse p400 to improve temperatures any recommendations dont want to spend anything over £30.00.
  #2
Old 11-11-17, 12:06 AM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
Some fans? How many fans do you require? Is £30 your limit for all fans or each? Do you need Static pressure (radiator fans) or Air Flow?
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #3
Old 11-11-17, 01:45 AM
Newbie
£30 For all fans if possible. Just standard airflow no rads or watercooling
  #4
Old 11-11-17, 10:14 AM
S_I_N's Avatar
S_I_N S_I_N is offline
OC3D Elite
might want to spell out your system and air flow now so others can better aide you. 30quid isnt alot for FANS these days hell I just spent 180$ for 6 ML fans last month.
__________________
Intel 7700K
Aorus Z270 Gaming K7
2x8GB GSKILL Trident Z 3200MHz
Intel SSD6 256Gb x2 in Raid 0
Samsung 850 EVO 1TB
EVGA GTX1080 FTW2 iCX Heat Killer IV block
Custom water Cooled Hardware Labs GTS360/240
ThermalTake Grand RGB 1000w PSU
Corsair Crystal 570X
  #5
Old 12-11-17, 02:36 AM
Newbie
Damn your pc must be icey cool LoL!. My specs
Case - Phanteks P400 Eclipse
Power Supply - EVGA Supernova 800w gold
CPU - i7-4790K
Motherboard - Asus z97-p
Cooler - Coolermaster hyper evo 212 (Fan facing case rear exaust)
Memory - Corsair vengeance 16GB 1600mhz
Primary Hard Drive - Samsung 850 EVO 240gb
Graphics - Msi Aero OC 1070ti 8GB Graphics Card (Blower Cooler)
  #6
Old 12-11-17, 03:20 AM
S_I_N's Avatar
OC3D Elite
you just need a couple fans set to intake on the top of the case since its dust filtered. Then you should be fine. Just look for air flow fans verses static pressure fans
__________________
Intel 7700K
Samsung 850 EVO 1TB
  #7
Old 12-11-17, 12:37 PM
Davva2004's Avatar
Davva2004 Davva2004 is offline
OC3D Elite
You already have a 120 at the rear so get two 140mm PWM fans at the front, £15 per fan gives you a wide range of choices. Run them from your motherboard header so they stay as quiet as possible and only ramp up when needed.
Top of the list for me would be the Noctua
NF-P14s redux-1200 PWM which are £13.99 from Overclockers.
__________________
  #8
Old 13-11-17, 09:39 AM
Warchild Warchild is offline
OC3D Elite
im guessing you want to aim for 3 fans then at that budget which will get you some "adequate" quality ones but nothing great. £30 is what I spend for 1 fan.
EK used to use some 120mm fans from Gelid which were decent and around £10 each. So 2 intakes and 1 exhaust might be a good option for you. Either that or what Davva posted above.
  #9
Old 13-11-17, 10:56 AM
Tolemac's Avatar
Tolemac Tolemac is offline
OC3D Elite
I use EK Vardars in my case I have no complaints with them and they are £16 each
__________________
Build Log: http://forum.overclock3d.net/showthread.php?t=72241
“If you knew the magnificence of the three, six and nine, you would have a key to the universe.” – Nikola Tesla
  #10
Old 13-11-17, 11:15 AM
OC3D Elite
Have they dropped in price? not bad at all, still slightly over his budget though. Definately a good option considering the airflow they provide even when not used as a rad fan.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
