Go Back   OC3D Forums > [OC3D] Hardware & Software > Software Section
Thread Tools Display Modes
  #11
Old 16-10-17, 09:36 PM
NeverBackDown NeverBackDown is online now
AMD Enthusiast
Originally Posted by BigDaddyKong View Post
It can cause instability with no clue. There are tons of people on Asus forums and OC.net that can confirm this. Plus, the uninstall does not get rid of everything. It takes a bit of CC Cleaner and some times manual reg edits to totally wipe the system of the program.
My 3770K rig would BSOD for no reason at all. Drove me nuts trying to track it down. Got rid of AI suite, and problems solved. There are tons of people still reporting the same problem even today.
Tbh any Asus software I've ever used is complete garbage, in fairness there isn't much I've had from any brand that works well. Ironically MSI in my experience is the most stable despite them not being the biggest company in terms of overall market share, Asus holds that crown by a massive Longshot.
__________________
I am Iron Man.
  #12
Old 16-10-17, 09:54 PM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Thanks for all the replies and I was going to do the bios manual it was just to keep the rest upto date but if it's crap I won't use it, and NBD you're right about Msi's live update been using it for years and it's always worked great.
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=32gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=MSI MPG341CQR=MSI GK80 Vigor=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #13
Old 16-10-17, 11:44 PM
AMD Enthusiast
Agreed. When I was new to PCs I used Live Update 5/6. Easiest thing ever.
__________________
I am Iron Man.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
