Go Back   OC3D Forums > [OC3D] Cooling Forum > Air Cooling
Thread Tools Display Modes
  #11
Old 11-10-17, 11:38 AM
AverageNinja's Avatar
AverageNinja AverageNinja is offline
Average Penis Too
Originally Posted by wedgie2007 View Post
thank my friend for doing a little research for me, i will add those fans to my cart..
No problem mate. Do note that I'm not sure how these fans exactly work as far as RGB goes. I think Corsair has a 'Fan RGB controller' that you can control the RGB lighting with, so I'm not sure if and how it works without that.
__________________
JavaBean: Ryzen 5 1600 / Corsair ML240L RGB / ASUS Crosshair 6 Hero / 16GB Corsair LPX / ASUS RX 580 Strix / Corsair RM750X / Fractal Design Meshify C
OC3D Overclockers Club Member:
Nr. #00 (Club Owner)
  #12
Old 15-10-17, 12:37 AM
poppa poppa is offline
Newbie
Hey guys noob here... i posed the same question on another fourm and was told to stay away from liquid cooler and was recommended to get a scythe cooler that it would be just fine .. this one was recommended https://www.newegg.com/Product/Product.aspx?Item=9SIA9ZH59H0503&ignorebbr=1&nm_mc =KNC-GoogleMKP-PC&cm_mmc=KNC-GoogleMKP-PCplaAccessories+-+General9SIA9ZH59H0503&gclid=CjwKCAjw64bPBRApEiwAJhG-fvSRCrursHj-XrJB_y470daOotsT2KwylWTG-CFY4lrCdDKawGkX7RoC4asQAvD_BwE&gclsrc=aw.ds .. i think they were trying to steer me away from liquid because of potential leaking .. i have no ideal about do the fail often? Whats your thoughts between the Scythe cooler vs water? Would the Mugen 5 be just fine for the i7 8700K .. I too plan to swap to Corsair HD120 fans.
TY for any help guys!
  #13
Old 15-01-18, 05:45 PM
clone38's Avatar
clone38 clone38 is offline
OC3D Crew
Grab the new corsair AIO I've got the H150i.
  #14
Old 15-01-18, 06:04 PM
scubasteve scubasteve is offline
Advanced Member
hey i got the noctua NH-U14s and so far its seems to be pretty good fair enough iv only had it running a few days but seems good for now i think , actually not sure if these temps are normal lol but lot cooler than i expected note i havent put it under any load yet tho
noob here as well but all i know is always go noctua first then compare everything else you thinking of getting with that , unless going with liquid cooling then i dont know lol cos i also para of leaks
  #15
Old 03-02-18, 04:50 AM
mutantaxe mutantaxe is offline
Member
Well RGB fans on the AIO coolers are only good usually if you have your RAD on the front.
I have the Corsair 115i RGB AIO at the top but have 6 RGB fans , 3 x 120mm Corsair at front , 2 140mm Corsair at bottom and one 140mm at rear. Have the Commander Pro to control fan speed and colors. Can set them up so front fronts will change colour base on the GPU and the 3x 140mm will change temps based on the CPU temps. The Link software is one of the better bits of software that manufacturers make ( I say this because it works perfectly for me )
And with all that fresh air the temps of my H115i is great and thats with the quiest fans that it uses.
Negative is with 2 wires per fan and the units to plug into ..one for the LED and one for the fans it can be very messy even in the Corsair 740 cube case
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
