Go Back   OC3D Forums > [OC3D] Graphics & Displays > Overclocking
Thread Tools Display Modes
  #1
Old 11-04-17, 10:54 AM
Vipermk2's Avatar
Vipermk2 Vipermk2 is offline
Newbie
Asus AI Suite 3 any good
I was just wondering if the the Asus AI suite is any good for overclocking or using the '5 way optimization' is just a basic optimising tool.
  #2
Old 12-04-17, 03:01 AM
BigDaddyKong's Avatar
BigDaddyKong BigDaddyKong is offline
OC3D Elite
I have used older versions in the past, and Windows did not like it. I have heard of others that have had problems from installing this version of the software. I won't try it now.
__________________
AMD R7 1800X-Asus Crosshair VI Hero-16GB GSkill 3200mhz-Corsair HX850-H110i-MSI 1070-Coolermast H500-Windows 10 Pro-Dell U3011-Dell 2007FP
  #3
Old 12-04-17, 07:11 AM
Warchild Warchild is offline
OC3D Elite
i never liked it. the fan setup and optimisation would sometimes reset and put everything to maximum.
  #4
Old 12-04-17, 10:35 AM
Thelosouvlakia's Avatar
Thelosouvlakia Thelosouvlakia is offline
Classy-Fried-Chicken
You don't need it and you don't want it, just get HWinfo for monitoring and just use the uefi for everything else. (I think you can do auto overclock in the uefi but I prefer tweaking stuff on my own)
__________________
Theory is when you have the "know how" but nothing works.
Practice is when everything works but no one knows why.
In our lab, theory and practice are combined: Nothing works and no one knows why
  #5
Old 28-12-17, 02:11 PM
RobM's Avatar
RobM RobM is offline
OC3D Elite
I have been using it this past couple days and whilst it can be handy for oc whilst in windows it has a tendancy to cause my system to randomly reboot, its only use as I see it is to get you a starting point to work from in bios
__________________
ASUS Prime x370 Pro | Ryzen 5 1600 | Antec 240 AIO | Corsair Vengance RGB 3000 2 x 8Gb | Asus Strix RX 470 | Samsung Evo 120gb ssd | Seagate Baracuda 1tb storage | EVGA 500w | Phanteks Entho ProM Acrylic Window | Windows 10 and Linux Manjaro
  #6
Old 28-12-17, 02:33 PM
Bartacus Bartacus is offline
OC3D Elite
AI Suite is garbage, and has been for years. This is coming from an Asus fanboy too. I won't buy any other motherboards, but their software sucks HARD.
__________________
Guts: Ryzen 3900X / GB Aorus Master / 16GB TridentZ 3600CL15 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: Corsair Force MP600 1TB NVME / 6TB RAID0 HDD array / 4TB RAID0 SSD array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads + 240 rad / Heatkiller reservoir / dual D5 pumps
  #7
Old 28-12-17, 04:51 PM
AMD Enthusiast
Don't bother and definitely don't use the bench mark feature. It's quite terrible.
__________________
I am Iron Man.
  #8
Old 28-12-17, 08:11 PM
OC3D Elite
Just remember uninstalling it does not get rid of it totally. You will need to reg clean when done to get it permanently gone.
__________________
  #9
Old 29-12-17, 10:16 AM
tinytomlogan's Avatar
The Guvnor
I always use revo uninstaller
The fan control side is OK but Id not use anything else. Theirs is probably the best out of the big 3 but Id always say go manual in the bios and learn it. All the softwares only really apply profiles and the volts are ALWAYS too high
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #10
Old 30-12-17, 11:14 AM
coffeefoot coffeefoot is offline
Advanced Member
I agree.
__________________
Asus Maximus XI Hero Z390,8086 K, 16 G.Corsair DDR4 L/P 3600MHz, 2 WD Black M.2 Nvme 500 GB. x 2, Corsair HX 1000, Gygabyte 2080 OC, Noctua D-15, LG 34UC80-B
Ultrawide.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
