Go Back   OC3D Forums > [OC3D] Customer Care Forums > NZXT Forum
Thread Tools Display Modes
  #11
Old 10-04-17, 04:25 AM
Avet's Avatar
Avet Avet is offline
OC3D Elite
About radiator placement this video from Bitwit explains a lot. CPU doesn't put out so much heat to affect other components when radiator is mounted as intake. But heat from GPU does affect CPU temps when radiator is mounted top as exhaust.
  #12
Old 27-04-17, 03:29 AM
Stephenms Stephenms is offline
Newbie
That is an excellent video! Really helped me understand radiator placement and put my mind at ease.
Well I still have yet to purchase an AIO. I'm still doing research and since my birthday is coming up I've decided to splurge a bit, I deserve it, i swear
The Kraken X62 is an amazing looking cooler so I've almost decided on that one for now.
The only issue I've been reading is the CAM software, which i'm okay with dealing with. And the hose placement. A lot of builds are having issues with ram being touched by the 90 degree angle hose fittings. The only confirmed motherboard with this issue, i could find, was the Maximus IX/XI something like that.
I have an Asus z170A board with the stock intel i7 1151 cooler right now. The dimensions of the stock cooler fan are x 93mm x 93mm x 35mm (according to newegg) the heatsink sits just slightly further out than the fans do. The kraken X62 pump dimensions are 80mm x 80mm x 52.9mm. I do only have 2 sticks of ram, in the center and end (away from the cpu) but if it's going to block a RAM slot, it seems counterproductive. I DO NOT plan on going higher than the two sticks of 8gb i currently have but you never know what the future holds.
Just curious as to what experiences you guys have had with this specific kraken X series. I'm about 85% sure it'll fit. I drew up and measured the size of the pump compared to the size of my current stock fan and it looked promising. I just don't want to buy it through newegg and it not fit and not be able to return it back to newegg.
  #13
Old 27-04-17, 05:12 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
I've not ran into any issues with Fitment and my memory is quite close on my X99A Gaming Pro Carbon and I've only had a few issues with the CAM software and I can say NZXT's customer service and warranty service is excellent ATM so if you run into any issues they will look after you and they revise their CAM software regularly so if you have an issue chances are they will fix it, Also realistically if it doesn't fit Newegg should take it back and swap it for a different unit if they won't then they aren't worth you spending your money with them goto Amazon or somewhere else also check with your legislative body on what your rights as a consumer are if you're worried before purchase
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=32gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=MSI MPG341CQR=MSI GK80 Vigor=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
