Go Back   OC3D Forums > [OC3D] Project Logs & Gallery > Desk & Work Area
Thread Tools Display Modes
  #21
Old 22-01-17, 04:08 PM
hmmblah's Avatar
hmmblah hmmblah is offline
Moderator
Originally Posted by chrismjurd View Post
you have two wavebirds! omg! nice dude. just nice!
I still love these controllers.
Originally Posted by bazskating View Post
looks good!
Thanks!
These are a little out of turn, but I actually started the recessed lighting first. Originally there was a fluorescent ballast in the middle of the room and two fixtures by the window. There's now 5 recessed fixtures operated by 2 switches. Three of them over the desk area and 2 along the back wall.
As I mentioned earlier I had planned on doing a drop ceiling, but later decided to do something that would fit with the industrial theme. I ended up buying sheets of corrugated metal. It can come down easy enough if I ever need to access electrical or plumbing in the ceiling and I think it looks way better. It also blocks any harmful radio waves the government is shooting my way. /tinfoilhat
The first sheet was easy to hang. I was able to rest in on some of the ventilation before screwing it to the ceiling joists. After that though it was damn near impossible to hold 8 foot sheets of flimsy metal in the correct spot while also operating a drill to screw these in place.
At first I was thinking way too complicated. I was going to construct some sort of scaffolding from the floor. Instead, I came up with this:
A single 2x4 and a small chunk of 3/4" plywood clamped to the ceiling. I made two of these and used them to hold up one sheet at a time as I progressed.
I really like the contrast between the white recessed lighting and the metal.
Lights out
I had planned on leaving the left and right sides open so you could see the copper pipes. Now I'm not so sure. I might paint the joists black to blend a little better or I might just box it in with more metal.
All in all, I'm happy with how it turned out.
__________________
CaseLabs Mercury S3 | AMD 3900X | ROG CH8 Impact | RTX 2080 Super | 16GB DDR4 | 1TB NVMe
Acer Predator Z35P
  #22
Old 27-01-17, 03:16 AM
hmmblah's Avatar
Moderator
I guess ceilings aren't your thing?
When thinking of the desk I knew I wanted something L-shaped and with no legs where the chair would go. I really couldn't find anything I liked and I honestly didn't feel like building something from scratch. I did the next best thing and bought 3 Ikea Linnmon tables.
You're supposed to use 12 legs (4 for each), but I went with a total of 9. This way I can wheel around freely without bumping my knees.
These tables are cheap and they look great.
On it's back:
Decided to go with a Kreg jig and dowels to join the tables together:
Jig for the dowels:
Dowels in:
I had assumed that the tables were solid around all the edges and hollow in the middle. Unfortunately, they are only solid on either end where the legs go. The sides and middle are hollow. Using a kreg jig and dowels where the L meets wasn't going to work. Instead I glued a piece of plywood on the hollow part and screwed it to the solid party of the other table.
All together;
You can also see an old 1930's era radio I'm using for another project....
There's still a little more work to come on the desk, but that will be later. It should make it a little more unique and fit in with the theme of the room while also strengthening and adding some weight to the desk.
The cabling will all be in the wall for the PC and monitor until it comes out underneath the table. This way the table can be butted directly up to the wall and I don't have any cables (except mouse and keyboard) running through the table.
This mount for the monitor is awesome. It moves freely up, down, left, right without the need to adjust anything and where you stop is where it stays.
Start of the cabling:
__________________
Acer Predator Z35P
  #23
Old 28-01-17, 05:31 PM
hmmblah's Avatar
Moderator
Finished shots of the PC layout:
Wiring behind monitor and PC:
Orthanc:
__________________
Acer Predator Z35P
  #24
Old 28-01-17, 06:28 PM
Davva2004's Avatar
Davva2004 Davva2004 is offline
OC3D Elite
That's a tidy job!
__________________
  #25
Old 28-01-17, 07:34 PM
WillSK's Avatar
WillSK WillSK is offline
OC3D Elite
Send a message via Skype™ to WillSK
Wall routed cables EEERRRYYYWWERERRRR <3 <3 <3
Nicely done dude
__________________
My Rig : Fractal S2 Case, ASUS Crosshair VIII Hero, Ryzen 3800X, Corsair H115i Platinum, MSI GeForce RTX 2080 GAMING X TRIO, 32 Gb Team Pro Dark RAM 3200Mhz, Samsung 970 EVO SSD, Samsung 850 Pro 500GB SSD, Seasonic Prime Ultra Titanium
  #26
Old 28-01-17, 08:33 PM
sheroo's Avatar
sheroo sheroo is offline
OC3D Elite
Wow!!! Absolutely love what you've done to the place. That ceiling is amazing. I too would like a floating monitor...
__________________
"All his life has he looked away... to the future, to the horizon. Never his mind on where he was."
  #27
Old 28-01-17, 08:44 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Yeah I like the ceiling too. And yeah those tables are hollow as I found out lol. I used metal straps between mine to keep them together and left all of the legs on
__________________
  #28
Old 29-01-17, 09:08 AM
SPS SPS is offline
Moderator
Wish I could be bothered to route cables through walls like that.. good job.
But you need more monitors for the size of that desk
__________________
  #29
Old 28-07-17, 03:39 PM
hmmblah's Avatar
Moderator
I finished some custom shelves awhile back and really love how they turned out. They are pretty simple consisting of black pipe and pine wood.
I started out by buying the pre-cut threaded pipe, caps, and floor flanges. They have an oily residue on them to inhibit rust so I used steel wool and mineral spirits to clean them off. There was also a sticker on each pipe that used an extremely stubborn glue that took a razor to remove.
After the cleaning I assembled and spray painted all the pieces.
The paint gives the pipes a worn or hammered look. Exactly what I was going for.
I also painted a bunch of these clips. These will hold the shelves to the pipes.
Using screws, I attached the floor flanges directly to the studs in the wall. The flanges are wider than a single stud so I had to double up the studs behind the wall. Luckily, there is an unfinished room on the other side of the wall so access was easy.
Another close-up of the pipe
And continuing on...
The last picture is missing, but at this point there are three columns of pipes on the wall.
Next it was on to the actual shelves. I wanted something that had knots and a noticeable grain that would show up well when stained. A few dents to make it look more worn would work as well. I went with pine because it fits all that criteria and luckily my local lumber yard stocks really crappy wood.
The planks were in all sorts of shape. None of them were flat so I used dowels between them to even them out. Attaching the glued boards later to the pipes would straighten them out further.
Glued and clamped
Closeup of the grain
Dried and sanded. There were 4 shelves total, one missing in this pic
The first coat of stain doesn't look good at all. I was second guessing my color choice at this point
After the second coat though I really like how it turned out and it would only get better with the poly applied
I did 3 coats of poly, lightly sanding between each coat
After that it was on to installation. Using 6 clips per shelf, I attached the shelves to the pipes
Shot from underneath
After all the shelves were attached, it was time to start filling them up. Any guesses as to what?
Yep, Star Wars UCS Lego sets.
__________________
Acer Predator Z35P
  #30
Old 28-07-17, 06:58 PM
AlienALX's Avatar
OC3D Elite
Love them. They look great. God, I could really show off my Fallout collection with shelves like that !
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
