Go Back   OC3D Forums > [OC3D] Graphics & Displays > Drivers & BIOS
Thread Tools Display Modes
  #1
Old 07-10-16, 05:18 PM
Captain Helltheo Captain Helltheo is offline
Newbie
Driver update freezing system
Hi
I tried to update my new RX470 drivers and it froze my system and after a restart my GPU just won't work at all need help.
running Win 10 64bit
i7-6700k
MSI Z170A G45 Gaming
MSI RX470 Gaming X 4GB
Theo
__________________
My Rig:
MSI Z170A-GD45 GAMING
MSI RX470 GAMING X 4GB
Inntel i7 6700K
Corsair H100i CPU cooler
8GB Corsair Vengance 3000Mhz
Corsair RM750 PSU
NZXT H440 red
  #2
Old 07-10-16, 06:27 PM
RobM's Avatar
RobM RobM is offline
OC3D Elite
are you able to boot using the onboard gfx?
__________________
ASUS Prime x370 Pro | Ryzen 5 1600 | Antec 240 AIO | Corsair Vengance RGB 3000 2 x 8Gb | Asus Strix RX 470 | Samsung Evo 120gb ssd | Seagate Baracuda 1tb storage | EVGA 500w | Phanteks Entho ProM Acrylic Window | Windows 10 and Linux Manjaro
  #3
Old 07-10-16, 07:30 PM
Newbie
Yes I am but if I try and install any drivers for my 470 same thing happens system freezes.
  #4
Old 08-10-16, 11:17 AM
Kushiro Kushiro is offline
OC3D Elite
Its it loose by any chance?
Old driver still work?
DId you clean the previous driver off before updating?
__________________
i7 5930k 4.7Ghz ~1.34v - Asus X99 Deluxe - G.Skill 32GB 2800mhz 4x8GB - NZXT Switch 810 White Edition - 3x EVGA Geforce GTX 980Ti - 2x Samsung 850 2TB - Corsair AX1500i
Watercooling - custom
  #5
Old 08-10-16, 11:34 AM
Newbie
I have reseated in each PCI-E slot and done older drivers but still freezes
  #6
Old 08-10-16, 05:29 PM
Thelosouvlakia's Avatar
Thelosouvlakia Thelosouvlakia is offline
Classy-Fried-Chicken
Try using DDU to clean your system of leftovers then try again
https://www.guru3d.com/files-details...-download.html
__________________
Theory is when you have the "know how" but nothing works.
Practice is when everything works but no one knows why.
In our lab, theory and practice are combined: Nothing works and no one knows why
  #7
Old 08-10-16, 06:51 PM
AMD Enthusiast
I'd make sure all cables from PSU to any endpoint are very snug in addition to anything connected to te motherboard. If they are loose, could cause the system to freeze. It'd be mostly sata cables, i had a "locked" sata cable, but it was actually ever so slightly bent on the pin side and was just enough to cause my system to freeze at random irregular intervals. Swapped it out and problem never occured again.
After that, it's either hardware related like memory or GPU, and other software options would be you or Windows somehow really messed up playing with drivers and it's causing crashes. If in safe mode with drivers disabled it fails, i'd lean towards hardware or a Windows update like the recently released Anniversary update for W10. It has caused problems for some.
  #8
Old 08-10-16, 09:17 PM
RobM's Avatar
OC3D Elite
I had similar issues a few months back not freezing but random restarts followed by boor failures, took me a week of testing to identify the seemingly good psu was the cause
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
