Go Back   OC3D Forums > [OC3D] General Forums > OC3D Member Reviews
Thread Tools Display Modes
  #11
Old 01-09-15, 08:03 PM
realneil's Avatar
realneil realneil is offline
OC3D Crew
I'm using crossfire extensively on my Intel-based PCs. Two R9-280X OC's in one box, two R9-290x OCs in another, and two R9-290X OCs in the third. The R9-290 cards automagically worked right away with both systems. (even though one system has cards that are not from the same company) The 280X cards needed a driver update and they worked fine after that.
I don't get the Crossfire problems that others speak of, so I consider myself lucky.
My AMD FX-9590 has a pair of GTX-760 4GB cards in it and it set-up, and ran easily.
__________________
  #12
Old 12-09-15, 04:37 PM
Nhirlathothep's Avatar
Nhirlathothep Nhirlathothep is offline
Newbie
i had ( recent amd cards):
- 2x 4850
- 2x 4870
- 2x 6850
- 2x 6870
- 2x 7970ghz
always with faith in crossfire,
always good at bench and "bad" in games.
every time i said "single card next gen", benchmarks tricked me.
fps at bench are not so important, the user experience with crossfire cards is terrible (only my opinion).
I don t like most AAA games and when you play unknown games or old games, u ll find crossfire worst than single card, better remove the second card.
And microstuttering always behind the corner.
only one opinion!
  #13
Old 12-09-15, 07:41 PM
MattyD7829 MattyD7829 is offline
Newbie
I was almost in the place that you are now with dual HD7950's. I bought one new, then trying to save some cash bough a second hand one from ebay along with an RM1000 and within 20 mins of plugging them in the 2nd hand card failed. Got fed up and got a 295x2 on the credit card. Turns out the RM1000 was also faulty so had to get a new psu as well.
  #14
Old 12-09-15, 09:43 PM
realneil's Avatar
OC3D Crew
Maybe the faulty RM1000 was to blame for the second 7950 failing.
__________________
  #15
Old 13-09-15, 01:19 PM
Kushiro Kushiro is offline
OC3D Elite
- 2x 4850
- 2x 4870
- 2x 6850
- 2x 6870
- 2x 7970ghz
only one opinion!
Guessing you didnt try the 9XX series from nVidia in SLI a while ago and you also didnt try AMDs CFX as of late either (either that or there is a problem with your config)
AMDs user experience is pretty darn good as of late. nVidia to the contrary.
__________________
i7 5930k 4.7Ghz ~1.34v - Asus X99 Deluxe - G.Skill 32GB 2800mhz 4x8GB - NZXT Switch 810 White Edition - 3x EVGA Geforce GTX 980Ti - 2x Samsung 850 2TB - Corsair AX1500i
Watercooling - custom
  #16
Old 13-09-15, 07:23 PM
realneil's Avatar
OC3D Crew
I agree, Crossfire is working great for me on three PCs. (all R9 series GPUs)
SLI is working well on one other PC as well.
Having dual graphics has come a long way if your system is configured properly.
__________________
  #17
Old 14-09-15, 08:13 AM
barnsley's Avatar
barnsley barnsley is offline
born in a.....
only one opinion!
To be fair I think you just got unlucky as they've improved Crossfire massively since the 7970s. While -arguably- still not as good as SLI at their current rate of improvement its surely only going to be a matter of time until they're as good as eachother.
__________________
Rig: i7 [email protected]|2x8gb HyperX Fury|Intel z97-AR|Corsair H75| 2x Nvidia 1070 founders edition|Superflower leadex 750W gold|Inwin 904| 970 EVO 500GB m.2|512GB evo 840| Crucial MX 500 500GB|ASUS MG279Q +Acer S240HL| Windows 10 pro, 8.1 pro| Kubuntu LTS
Audio: Silverstone EB01-E+EB03+DT 770 Pro 250Ω+Samson SAGOMIC
Ducky Legend (cherry red)+Zowie AM-FG
  #18
Old 14-09-15, 09:46 AM
OC3D Elite
Undoubtedly. TBH never actually ever had any issues with CF aside from the frames before Frame pacing was introduced. That and of course the occasional game where its too old and isnt supported.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
