Go Back   OC3D Forums > [OC3D] Cooling Forum > Sub-Zero Cooling
Thread Tools Display Modes
  #1
Old 21-10-14, 04:35 PM
ObscureParadox ObscureParadox is offline
Advanced Member
8GHz anyone??? :P
http://valid.canardpc.com/d1s8ai
CPU was also very good at keeping stable around the 7.4-7.5GHz mark. Will want to give this CPU another go on LN2 with a different BIOS and CPU pot since I should be able to get around a 7.8GHz Super Pi 32M stable result with it too.
Here's some more screenshots for anybody interested ;
__________________
  #2
Old 21-10-14, 04:41 PM
TPC's Avatar
TPC TPC is offline
OC3D Elite
1.35V and 7.5 ghz?!? thats awesome! but that was too with LN2 right? how high do you get it under water/air?
  #3
Old 21-10-14, 04:43 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
Hells bells that's impressive for a Vishera! Nicely done.
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #4
Old 21-10-14, 04:44 PM
Advanced Member
The voltage is wrong I had to turn off the proper voltage detection on CPU-Z in order to get CPU-Z to run. Real voltage is in the 1.84-1.88v region depending on the benchmark, some are as high as 1.92v I think.
It's 5.1 or 5.2GHz stable on water with around 1.45v so it's a fairly decent chip, can't remember exactly though since it's been a year and a half since it was last run on anything other than sub zero cooling :P
__________________
  #5
Old 21-10-14, 04:58 PM
kilobravo kilobravo is offline
OC3D Elite
Send a message via MSN to kilobravo
Nice chip you have there mate.
And i also like your ram,cas7 at 2400mhz+ is sweet.
Also still have them nice hd5970`s.
__________________
  #6
Old 21-10-14, 05:04 PM
WYP's Avatar
WYP WYP is online now
News Guru
An 8GHz overclock with all 8 cores enabled? Wow.
__________________
_______________________________
Twitter - @WYP_PC
  #7
Old 21-10-14, 05:07 PM
MadShadow MadShadow is offline
OC3D Elite
Damn thats impressive dude
__________________
|i5 4460|8GB RAM|R9 380 4GB|ASUS Z97-I Plus|WD Blue 1TB|Corsair RM650|Phanteks Enthoo EVOLV ITX|
  #8
Old 21-10-14, 05:20 PM
Tripp's Avatar
Tripp Tripp is offline
too many shrooms
very impressive fella
  #9
Old 21-10-14, 05:28 PM
WYP's Avatar
News Guru
Do you have any pictures of the hardware and more info on your cooling method? I'd be interested in making this front page.
What volts are you using for your 7.4-5 GHZ overclock?
Very impressive stuff.
__________________
Twitter - @WYP_PC
  #10
Old 21-10-14, 06:28 PM
Advanced Member
Yeah sure
So the volts I was using for the 7.4-7.5GHz overclocks were all 1.84-1.88v depending on the benchmark. One module hit a wall at this speed whereas the others were stable up to 7.7GHz on multi-threaded benchmarks which was a bit of a pain. For the PiFast result I used a voltage of 1.95v but that was also at 7.9GHz which was absolutely needed to keep it bench stable at that speed. No Super Pi runs were done as there is a way to unlock extra codesets to get the benchmark to run faster which I had forgot to do and had no time to do on the day.
The motherboard was a Crosshair Formula V (regular not -Z) and the ram was a set of Corsair Dominator GT v7.1s (2x2G which I actually bought off a user here about 2 years ago. Both were on regular ambient cooling, however they were a bit colder than ambient due to the cold vapour coming off the pot running onto them both. The ram was at 2500MHz 7-12-7-28 1T @1.92v for almost every benchmark and was absolutely rock solid stable at those speeds too, will hopefully get them cold too soon and see what they can do, hoping for around 2800MHz 6-10-6-28 1T.
The CPU was cooled down to -196c using LN2, and the pot I used for this particular run was a SF3D Inflection pot (not the newer EK one) and held the loads really really well, would recommend this pot to anyone who wants to get into LN2 cooling.
I will look for some pictures for you later on tonight since I have to go to football training now until 10. I think all my photos are on my phone unfortunately (Galaxy S4) but will see if I took any with my DSLR too
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
