Thread Tools Display Modes
  #51
Old 12-06-19, 07:36 PM
Kei's Avatar
Kei Kei is offline
Advanced Member
Finally picked up a second OM3 fibre so I can do a test run at 10Gb. Performance in one direction looks pretty good, but not so good in the other direction.
Running my threadripper workstation with the intel x710 as the iperf server net 7Gbps with the 9600k/solarflare NAS as the client. The other way around only got 3.5Gbps. Currently I've adjusted the Tx/Rx buffers on the intel card to their maximums but not made any changes to the solarflare as I'm less familiar with linux driver tweaks.
__________________
Gigabyte Aorus X399 Gaming 7 ⁞⁞ Ryzen TR 1920x ⁞⁞ EK Blocks + αcool XT45 rads ⁞⁞ AMD Radeon Vega 56 ⁞⁞ 32GB 8 Pack 3200C14 ⁞⁞ Enthoo Primo
Seasonic Prime 750W ⁞⁞ Polaris 961 256GB ⁞⁞ 850 Pro 512GB ⁞⁞ M500 240GB ⁞⁞ WD Se 4TB & 1TB x2 ⁞⁞ Samsung C27HG70 + Dell 2408WFP
Ducky Shine 5 ⁞⁞ AJA Kona LSe ⁞⁞ RME HDSPe AIO ⁞⁞ Marantz AV7701 ⁞⁞ Tannoy SRM 10B ⁞⁞ AKG K601 ⁞⁞ Beyer DT770
  #52
Old 13-06-19, 05:26 AM
FTLN FTLN is offline
OC3D Elite
Why not schedule a restart of the Plex every couple of days ? It should be pretty easy to automate.
__________________
Intel Core i9 9900kK @ 5.00GHz @1.275v - Asus ROG Maximus Hero - Corsair 3000mhz CL16 LED 4x16GB SKHYNIX - Thermal Take View Glass - PM961 1TB x 2 RAID0 - Nvidia GTX 1080 Ti - Corsair H110i - Corsair Commander Pro - Asus ROG Swift PG279Q 2560x1440P G-Sync 165Hz
  #53
Old 13-06-19, 11:24 AM
Kei's Avatar
Kei Kei is offline
Advanced Member
Since the reboot after installing the new NIC, plex memory usage seems to have remained reasonably constant.
I'm now chasing 10gig ethernet issues on the windows machines.
__________________
  #54
Old 21-06-19, 06:39 PM
Kei's Avatar
Kei Kei is offline
Advanced Member
The windows 1903 update seems to have mostly resolved the issues I was seeing with iperf, though I'm still getting better speeds to the server than I do from it.
I bought some OM3 fibres from FS along with some LC-LC links for the wall boxes I got from RS a few months back. Wall boxes should be pretty resilient as the fibres will enter at the base of the boxes keeping the connection virtually flush with the wall to avoid breaking them.
Since I now have sufficient fibres for a proper test run, it'd be rude not to. Just a quick test to make sure all ports and fibres work ok, I connected the server with two links using the 3 avago transceivers I have. All working great, the juniper doesn't seem to mind the avago transceiver.
Quick file transfer test from my pc to the server. This is off an nvme ssd to avoid sata bottlenecks. Normal transfers will be a fair bit slower sadly but at least now I can have two pc's copying to the server and two tv's streaming from it without interruption.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
