Go Back   OC3D Forums > [OC3D] Hardware & Software > Software Section
Thread Tools Display Modes
  #11
Old 22-06-13, 04:52 PM
Chris230291's Avatar
Chris230291 Chris230291 is offline
OC3D Crew
Cheers mate i'll take a look.
Handbrake just totally butchered a DVD :/ lol
EDIT.
Is there some sort of chart i can refer to that will tell me the best format to convert "x" format to, with the correct/best/optimised settings?
__________________
i7 3770K - GTX 780 SLI - GA Z77X-UP5-TH - 16GB 1600MHz Vengeance - SanDisk Extreme 240GB SSD - 750W Supernova G2
  #12
Old 22-06-13, 05:17 PM
I Hunta x's Avatar
I Hunta x I Hunta x is offline
OC3D Elite
there is no best format realy, they are just containers at the end of the day, if you want to keep as much quality as possible set the res to be identical to the source file, and dont put the bitrate to low.
I generaly stick with about 6.5-7.5Mbps for 1080p, 2.5-3.5Mbps for 720p and 1.5-2Mbps for dvd, higher of the range if its fast paced/lots of explosions ect like an action movie and lower of the range if its something with slower camera work say something like forest gump, alot of fairly static camera work (minus the war section) as you have a ton of storage you could just keep the the upper ranges tbh.
__________________
i7 970 @ 4.2Ghz - NH-D14 | Gigabyte x58a-oc | Corsair AX850 | CM Cosmos S
4x4Gb Samsung Green in 3+1 Tri Channel - 1900Mhz c10 1.3v | R9 290 | Samsung 840 Evo
Beyerdynamic Custom One Pro + V-Moda Boompro
-Need to fit-
Xspc Rasa | Phobya G-Changer 240 + 360 | Phobya dc12-400 | 7x Orange Xigmatek XLF 120mm
| Alphacool Copper fittings
  #13
Old 22-06-13, 06:10 PM
OC3D Crew
Are there any programs that can work out the best solution for me? It seems like a mission to keep testing different settings for each piece of media.
__________________
  #14
Old 06-02-14, 01:39 AM
Able Zhang Able Zhang is offline
Newbie
I am using Pavtube ByteCopy which can meet my demands of convert Blu-ray/DVD to MKV with lossless quality. You can download the free version to have a try. Hope it can help you as well.
  #15
Old 06-02-14, 02:42 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
DVD Fab Platinum will also convert your bluray and dvd movies to multiple file types it's what I have used myself in the past to put my dvd's onto my phone so have a look at it
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=32gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=MSI MPG341CQR=MSI GK80 Vigor=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #16
Old 12-07-14, 11:27 AM
FourLions's Avatar
FourLions FourLions is offline
Newbie
I use this its called Megui best prog by far is a bit tricky to set up but when u get use to it its best one for u
http://forum.doom9.org/showthread.php?t=96032
  #17
Old 15-06-17, 02:10 AM
Bobtang Bobtang is offline
Newbie
You can give a try at EaseFab's LosslessCopy tool. It's very easy to use and provides a high definition rip without quality loss.
  #18
Old 15-06-17, 02:59 AM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
Please don't necro threads, this thread is well over 3 years old.
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
