Go Back   OC3D Forums > [OC3D] Project Logs & Gallery > Desk & Work Area
Thread Tools Display Modes
  #51
Old 13-01-19, 11:43 AM
Kei's Avatar
Kei Kei is offline
OC3D Crew
Put the brother labeller to use in my room today and finally labelled all of the MDU outputs. Slightly annoying spacing between 6 & 7 as I had to build it in two 195mm labels as the max label length is 300mm and the MDU strip is 390mm long.
Need some flexible tape and I can label all of the signal cables too as they are a real rats nest.
__________________
Gigabyte Aorus X399 Gaming 7 ⁞⁞ Ryzen TR 1920x ⁞⁞ EK Blocks + αcool XT45 rads ⁞⁞ AMD Radeon Vega 56 ⁞⁞ 32GB 8 Pack 3200C14 ⁞⁞ Enthoo Primo
Seasonic Prime 750W ⁞⁞ Polaris 961 256GB ⁞⁞ 850 Pro 512GB ⁞⁞ M500 240GB ⁞⁞ WD Se 4TB & 1TB x2 ⁞⁞ Samsung C27HG70 + Dell 2408WFP
Ducky Shine 5 ⁞⁞ AJA Kona LSe ⁞⁞ RME HDSPe AIO ⁞⁞ Marantz AV7701 ⁞⁞ Tannoy SRM 10B ⁞⁞ AKG K601 ⁞⁞ Beyer DT770
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
