Go Back   OC3D Forums > [OC3D] Off Topic > Off Topic Chat
Thread Tools Display Modes
  #9691
Old 22-12-18, 06:21 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Originally Posted by AlienALX View Post
For after my sex change op in January.
ROFL
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - RTX 2080 Ti @ 2000/7500 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
  #9692
Old 23-12-18, 01:53 AM
Dawelio's Avatar
Dawelio Dawelio is online now
OC3D Elite
Originally Posted by Kaapstad View Post
This will give me something to play with at xmas.
Right, so that’s what £4800 looks like...
  #9693
Old 24-12-18, 11:46 AM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
You know me and my sound cards.. Never had an ST or STX before, so pulled the trigger on one of those for £30. Only downside is it is PCI, but I have one of these (I bought it years ago and it worked perfectly, but alas I was trying to get a Soundblaster card to work and this was before the big driver fix)
So I should be able to get it working. Like I say, the PCI to PCIE thing worked a treat, but then it did cost me thirty pounds.
__________________
  #9694
Old 25-12-18, 08:56 PM
Warchild Warchild is offline
OC3D Elite
you may have some problems with ssd cards if you have a gpu, sound card and and m.2 all connected. Some mobo disable sata slots 1,2 and 3.
  #9695
Old 25-12-18, 09:12 PM
Dicehunter's Avatar
Resident Newb
Just ordered the Lian-Li dual 8 pin and 24 pin RGB cables as well as a 16 foot RGB strip so I can put it at the back and side of my desk that's against the wall, ALL THE RGB !!!
__________________
  #9696
Old 25-12-18, 09:18 PM
AlienALX's Avatar
OC3D Elite
Pull a minger for Christmas lol.
Pretty sure my strips are made by them.
__________________
  #9697
Old 25-12-18, 09:35 PM
OC3D Elite
Dont worry Dice. We all grow up one day
  #9698
Old 26-12-18, 01:45 AM
Dicehunter's Avatar
Resident Newb
They'll all be set to red or white not rainbow puke, If you see them in the flesh they look very cool.
__________________
  #9699
Old 28-12-18, 12:16 AM
AlienALX's Avatar
OC3D Elite
After four destructive ROM updates the phone I have still will not let me set a wallpaper. So I've had it. Decided whilst the phone I am using was all stock (it was soul destroying to spend hours putting everything back) I may as well just move to another phone.
Got a great deal on that, so that will do me for another year.
__________________
  #9700
Old 28-12-18, 12:31 AM
Dawelio's Avatar
OC3D Elite
My lord... I've never understood why there are phones with such tiny keyboard on it. Just why? And can you even type on those? If you've got big fingers, then you're in some trouble.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
