Go Back   OC3D Forums > [OC3D] Off Topic > Off Topic Chat
Thread Tools Display Modes
  #5221
Old 14-08-15, 12:28 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Originally Posted by AlienALX View Post
I was going to ask you what you were doing about a monitor.. What happened with the cooler? did you upgrade it or something?
I upgraded the fans on the FX to 2 x SP120mm white LED editions in push pull
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - RTX 2080 Ti @ 2000/7500 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
  #5222
Old 14-08-15, 12:31 PM
cooperman's Avatar
cooperman cooperman is offline
OC3D Crew
I was running out of cider xD
__________________
i5 4690-Gigabyte Z97P-D3-16Gbs 1866Mhz Kinston HyperX Fury Black-Asus GTX 980 Corsair h80i-sandisk 256gb ultra plus-250gb Intel SSD-WD Blue 500gb-Seasonic M12-620w-Cooler master haf xb.
  #5223
Old 14-08-15, 12:33 PM
Tolemac's Avatar
Tolemac Tolemac is offline
OC3D Elite
Originally Posted by Dicehunter View Post
Sold my 4K monitor and got the BenQ XL2730Z, Identical to the ROG Swift in capabilities albeit with a metric butt ton more gaming orientated features and costs less, Oh and not Asus so no dead pixels
1440P, 144Hz, Freesync 40Hz-144Hz
Pleased for you there matey I remember my mate buying a benq monitor and it knocked spots off the Acer one I had both 1080p three years ago
__________________
Build Log: http://forum.overclock3d.net/showthread.php?t=72241
“If you knew the magnificence of the three, six and nine, you would have a key to the universe.” – Nikola Tesla
  #5224
Old 14-08-15, 12:35 PM
Dicehunter's Avatar
Resident Newb
You are gonna be wasted
Thanks bud
I've actually had BenQ a number of times and they are superb monitors with a butt ton of features built in that leave the competition in the dust
__________________
  #5225
Old 14-08-15, 12:54 PM
cooperman's Avatar
OC3D Crew
Thats the plan lol
__________________
  #5226
Old 14-08-15, 02:36 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Dice, how was it taking the Fury apart to get rid of the stock fan? I have to do mine soon...
__________________
  #5227
Old 14-08-15, 02:54 PM
SuB's Avatar
SuB SuB is offline
The Webmaster
haha Turbocider!
__________________
Gigabyte Z390 Aorus Pro | i7-8700k | 32GB Corsair Vengeance 3000Mhz DDR4 | nVidia RTX 2080Ti | Creative Audigy Rx | 1Tb Samsung 970 EVO+ M.2 | 1TB Samsung 860 QVO | 2TB Seagate Barracuda | Corsair RM850 | Fractal Define S | Noctua NH-U14S | Roccat Kone Optical - Navy Storm | QPad MK85 Pro w/ Cherry Red MX | DELL U2413 + 2 x U2412M | AKG K702's | AKG K7XX S/N#000016 | Beyerdynamic DT770 Pro 250Ohm | TM Hotas Warthog Stick and Throttle | Saitek Combat Pro Pedals | TrackIR 5 | TrackClip Pro
Notice: Don't feed the trolls!
  #5228
Old 14-08-15, 03:16 PM
Tolemac's Avatar
OC3D Elite
Originally Posted by SuB View Post
haha Turbocider!
I would call it WALLOP JUICE
__________________
  #5229
Old 14-08-15, 03:19 PM
Dicehunter's Avatar
Resident Newb
It's pretty easy to be honest.
Just undo the 4 screws on the underside of the card and the metal plate just comes off, Then unscrew 2 screws holding the little plastic clip into place, Remove it and then remove the fan header gently.
Once you've removed the fan header getting the cable out of the housing can be a little tricky but it just take a minute or 2 to squeeze it through the small gap the cable is coming our of, Once you've removed the fan and cable completely from the housing screw the little plastic retention clip back on, the metal underside plat back on and you're good to go.
You'll have to plug another fan you want to use into either your mobo or wire it to your PSU as the GPU's fan header is a weird flat'ish 5 pin thing.
All in all though it's quite simple
__________________
  #5230
Old 14-08-15, 03:21 PM
AlienALX's Avatar
OC3D Elite
I'll be running some 1500 RPM fans at 12v so I won't need to use the header
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
