Go Back   OC3D Forums > [OC3D] Hardware & Software > Software Section > Games
Thread Tools Display Modes
  #1081
Old 04-07-19, 01:25 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Originally Posted by Warchild View Post
Sure. I need to get my whisper of the worm done too
I'm off all this week and all next week so any time is fine with me, Whisper I'm a bit rusty on though
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - RTX 2080 Ti @ 2000/7500 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
  #1082
Old 04-07-19, 02:04 PM
Warchild Warchild is offline
OC3D Elite
Same. There is so much old content I want to do. But nightfalls etc too. Its nice to come back to the game. Division 2 became as stale as Anthem!
  #1083
Old 04-07-19, 02:37 PM
Dicehunter's Avatar
Resident Newb
I'm up for anything, Strikes, Raids, Nighfalls, Forges, Menagerie, Helping with quests, Just name it
__________________
  #1084
Old 04-07-19, 02:49 PM
OC3D Elite
cool. saw you just accepted the invite
  #1085
Old 21-08-19, 11:35 AM
Dicehunter's Avatar
Resident Newb
Switching to Intel from the 3900X REALLY shot my frames up in D2, Quite impressed, Same settings, Same 1080P res, Same memory, Same GPU, Same location, Same character, Same items/armor/weapon equipped etc... FPS in the top right of each pic.
Before my AMD mobo went pop I did repeat these tests multiple times, Clean driver install, Up to date mobo drivers etc...
Some games really do favor 1 vendor over the other.
__________________
  #1086
Old 21-08-19, 12:02 PM
Damien c Damien c is offline
OC3D Elite
That sort of performance drop is what is what would stop me from buying AMD for my next cpu, for my gaming pc because it's mainly Destiny 2 and The Division 2 that I play on my pc.
I wonder though if that performance drop is in part way down to the issues they had with the 3000 series cpu's when they launched, is it like that in other games or is D2 an outlier?
__________________
  #1087
Old 21-08-19, 12:44 PM
hmmblah's Avatar
hmmblah hmmblah is offline
Moderator
I wonder why the difference in GPU usage. That would explain the fps jump. Your Intel system is at ~90% GPU whereas the AMD system is at ~50%.
__________________
CaseLabs Mercury S3 | AMD 3900X | ROG CH8 Impact | RTX 2080 Super | 16GB DDR4 | 1TB NVMe
Acer Predator Z35P
  #1088
Old 21-08-19, 01:20 PM
Dicehunter's Avatar
Resident Newb
Well in general in gaming the 9900K is still top, Some games it's 10FPs some games it's A LOT more, I think it just comes down to the fact that a lot of games are still coded on Intel machines FOR Intel machines.
Even my 2700X performed quite bad in Destiny 2 compared to the competition.
The low GPU usage is due to it being CPU bound i.e 1080P, If I was playing at 1440P it would likely be a much smaller gap.
__________________
  #1089
Old 21-08-19, 01:52 PM
hmmblah's Avatar
Moderator
Ah, missed that part. Are you playing at 1080P to run at a higher refresh rate? All the early benches showed 1080P was where Intel pulled ahead. Seems so backwards though running that resolution.
__________________
Acer Predator Z35P
  #1090
Old 21-08-19, 02:24 PM
Dicehunter's Avatar
Resident Newb
1080P 240Hz monitor
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
