Go Back   OC3D Forums > [OC3D] Customer Care Forums > NZXT Forum
Thread Tools Display Modes
  #21
Old 23-07-12, 11:08 PM
| raVen |'s Avatar
| raVen | | raVen | is offline
OC3D Crew
Originally Posted by blair View Post
yea switch 810 not sure it would be worth it just to fit another 120mm rad in.
I think you mean "another 120mm fan in"
It is worth it mate.
__________________
FROST
CaseLabs M8
i7 2600k-5.02Ghz, MSI Mpower Z77, Corsair Dominator Platinum 1866, 7970 in Crossfire, Corsair AX 850, Samsung 840 PRO 250GB+ WD G 3TB+ WD B 500GB, Asus Essence STX + AKG K550, Gigabyte Avia Osmium + SteelSeries Sensei
Custom watercooliong
Project CaseLabs M8
  #22
Old 23-07-12, 11:25 PM
blair blair is offline
OC3D Crew
no, i mean rad i need to have the top rad fittings at the front of the case then i can fit a 120mm fan and rad in the back, with the fittings on the top rad at the back it would clash with the back rad.
__________________
My Rig:
I7-6850K - 4x8GB 3000Mhz Corsair Vengance - 2x8GB Asus Strix GTX1080 - Asus Rampage V Edition 10 X99 - 500GB Samsung Pro 950 SSD + 500GB SSD + 3TB HDD - 1000W Corsair Power Supply
Laptop:
Surface Book I5-6300U 3Ghz - 8GB Ram - 256GB NVME SSD - GT940m GDDR5
  #23
Old 23-07-12, 11:34 PM
| raVen |'s Avatar
OC3D Crew
Ok I thought that you want to cut off this optical bay plate from the top to install one more fan...
Depends how thick 120mm rad you want to use?And how thick rad you have on the top?
__________________
FROST
CaseLabs M8
Project CaseLabs M8
  #24
Old 23-07-12, 11:36 PM
BCMods's Avatar
BCMods BCMods is offline
Member
Originally Posted by HeaT View Post
Looks nice
Thanks
__________________
Intel i5 3570k - Gigabyte G1 Sniper M3 - 16GB Corsair Vengeance LP @ 1600MHz - MSI Radeon 7950 - 60GB OCZ Vertex 2 - 1TB Western Digital Caviar Black - OCZ ZS 750w - Parvum Systems S1.0
XSPC Raystorm - EK-FC7970 - Swiftech MCRES V2 - Laing D5 with EK D5 X-Top - Alphacool NexXxoS UT60 240mm - Alphacool NexXxoS ST30 240mm - XSPC UV Green 1/2 3/4 Tubing
BenQ G2320HDB - Corsair K90 - Logitech G500 - Steelseries QcK+ - Blue Microphones Snowball
  #25
Old 23-07-12, 11:37 PM
BCMods's Avatar
Member
Surely you could just drill two holes for the fittings to go trough?
__________________
  #26
Old 23-07-12, 11:49 PM
OC3D Crew
na id need a 90 degree fitting on the rad as well and the plate is in the way and if i put it all together the res fill port is half covered by it, be easier to cut cut the whole thing out.
would cutting it all out weaken the bays too much?
__________________
My Rig:
Laptop:
  #27
Old 25-07-12, 09:34 PM
| raVen |'s Avatar
OC3D Crew
It will have a bit of flex, but its ok. Dont worry.
__________________
FROST
CaseLabs M8
Project CaseLabs M8
  #28
Old 26-07-12, 06:40 AM
maniac's Avatar
maniac maniac is offline
OC3D Elite
My lovely Switch 810 Still waiting on a couple of fans, led sleeved kit and a backplate for the graphics card :P
__________________
NZXT Switch 810 - Intel Core i7 950 - EVGA GTX580 SLI - Asus P6T - G.Skill Pi Series 6GB
Corsair H110 - Corsair HX850 - Intel 520 120GB - Acer V243H - Logitech G510 - Corsair M65
  #29
Old 26-07-12, 05:10 PM
| raVen |'s Avatar
OC3D Crew
My Ch2o
Build Link http://forum.overclock3d.net/showthread.php?t=41136
__________________
FROST
CaseLabs M8
Project CaseLabs M8
  #30
Old 28-07-12, 05:14 AM
PBaines's Avatar
PBaines PBaines is offline
Member
Send a message via Yahoo to PBaines
Build I have done over the years
Lights on;
Lights off;
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
