Go Back   OC3D Forums > [OC3D] Cooling Forum > Sub-Zero Cooling
Thread Tools Display Modes
  #11
Old 09-10-11, 07:18 PM
SmoulderingCircuits SmoulderingCircuits is offline
OC3D Elite
Originally Posted by S_I_N View Post
that would be ok as long as there was a way to get rid of it. Most things like this just absorb and absorb til they cant anymore then bamm leak it out. Better off still preventing it all together.
I meant if it could cause what it has absorbed to evapourate at the same time as absorbing new moisture
__________________
Subroutine
Lubuntu 12.10 | 2880x1024 | AMD E-350
  #12
Old 09-10-11, 07:47 PM
Rasmus66's Avatar
Rasmus66 Rasmus66 is offline
Advanced Member
I use art eraser and plastic paint
__________________
Voltage - The cause and the solution to all our problems
  #13
Old 13-10-11, 04:28 AM
cerbrus2 cerbrus2 is offline
Banned
Just submerge the board in mineral oil.
  #14
Old 14-10-11, 07:48 AM
Rasmus66's Avatar
Advanced Member
It works but it is hopelessly impractical if you want to change anything on the motherboard.
__________________
  #15
Old 15-10-11, 12:02 PM
OC3D Elite
Especially physical incremental OC buttons like on the X58-OC
__________________
Subroutine
  #16
Old 07-11-11, 03:32 PM
badatgames18 badatgames18 is offline
Newbie
eraser is the first layer.. covering the entirety of the cpu area.. from ram sockets to vrm area.
then a layer of shop towels..
finally elastomeric closed cell foam... i do this for all things subzero
only killed 3 motherboards (before i finally figured it out)
  #17
Old 09-11-11, 10:10 PM
MSIRawZ's Avatar
MSIRawZ MSIRawZ is offline
OC3D Elite
Send a message via MSN to MSIRawZ Send a message via Skype™ to MSIRawZ
There are many different ways and combo'. Each to their own preferred method. Best trying out what suits you best. Once you find your own preferred method of insulation, you'll setup in no time like a rhythm. The key is not to rush it. Rush it.. and you pay for your mistake(s).. literally.
Me? I use putty eraser around the socket covering that whole bare area and around the DIMM slots up to the southbridge. Best to remove all heatsinks so you know your covering the whole PCB area. I like to build up a raised area around the socket to catch any loose condensation build up stopping it from running down the board into missed areas or none-insulated gaps and cracks. Two layors of neoprene around the socket area nicely cut to match and fit around the pot and socket with vaseline around the socket and between the two neoprene sheets. Neoprene gasket around the pot (should come with your new pot) and then a towel of sorts or thick quality paper towel wrapped around the pot. If you are running phase 24/7 put vaseline or dieletric grease into the socket area. Same with LN2, don't need to with DICE. Vaseline and neoprene on the back of the board around the underside socket area too as condensation likes to build up there if uncovered. Put it between the mounting backplate and board.
  #18
Old 27-08-12, 05:25 PM
SeekNStrike SeekNStrike is offline
Newbie
When you insulate you have to also consider whether you need to rma or sell on. Eraser and putty are easy to remove without trace.
  #19
Old 02-09-12, 02:30 PM
almighty15 almighty15 is offline
Newbie
Liquid electrical tape on the motherboard, it peels off when not needed and leaves no residue and a layer of kneaded rubber eraser on top of that.
__________________
Fastest Phenom 2 x6 1075T in the UK clocked at 4.8Ghz - Proof!
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
