Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
Thread Tools Display Modes
  #11
Old 27-05-15, 05:37 AM
Tolemac's Avatar
Tolemac Tolemac is offline
OC3D Elite
I went for the bay res combo as the case I have wouldn't show off a seperate res I actually bought the XSPC D5 vario (comes with screwring and O ring) and the res separately as it worked out cheaper for me to just screw the pump into the res 2 minutes
work and £10 saved as I would have unscrewed the pump from the res anyway to make sure the O ring was fitted properly its a shame you don't live in the UK as I have 4 spare screws for your cpu block because I bought the kit that came with intel fixings as well as AMD and the screws are exactly the same .
I would have preferred a separate res and pump for aesthetics but it really depends on what case you have.
BTW if you are going to add a GPU block please remember that the biggest radiator should cool your CPU as the GPU responds to watercooling better
__________________
Build Log: http://forum.overclock3d.net/showthread.php?t=72241
“If you knew the magnificence of the three, six and nine, you would have a key to the universe.” – Nikola Tesla
Tags
corsiar, cpu, firstloop, temps, watercooling
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
