Thread Tools Display Modes
  #101
Old 29-05-13, 03:43 PM
alpenwasser's Avatar
alpenwasser alpenwasser is offline
OC3D Elite
Originally Posted by maniac View Post
hooleee geezus that cabling looks sweet :P
Thanks!
the only thing i'm not really liking is the whole bunch of lacing on the 24 pin and on the molex and sata. personally i think it'll look cleaner without them
You mean those fat bundles of lacing cord around the whole thing that make it round? Yeah
those are a bit large at the moment. Personally, I'm quite happy with the 24 pin as it is, but the
other one will have to be redone, sine it's not only very large but also not clean. But I've had to
bind it very tightly to get it to fit through the hole in the PSU's side.
I don't think I'm done yet with the lacing to be honest, but I'll first mount everything in, and then
I'll see how orderly I can get everything to look with the minimal amount of lacing cord. It's an
iterative process I would say.
  #102
Old 29-05-13, 08:21 PM
OC3D Elite
Back Panel Progress
Back Panel - Progress
I've been working on the back panel. Fitting is done, what's left is more or less half the painting
and some finishing touches.
Paint
Since I don't want to repaint the entire panel, I'm using this to paint each hole individually.
Yes, it's a rather slow process.
(click image for full res)
Back Panel - Inner Side
This side has not been painted yet. I thought this would provide some good contrast to see
the difference.
Back Panel - Outer Side
The screw holes won't be painted, since they won't be visible (also, they are threaded).
Back Panel - Test Fit
It fits nice and snug, and it's all solid and good.
Back Panel - M/B Test Fit
The M/B fits nicely to the new back panel. The I/O shield lines up perfectly.
You can also see the screws used to mount the panel. As you can see, there's no nuts involved, the threads
are directly in the back panel. It's thick enough for this to work nicely, as long as you're not too brutal there's
no danger of ripping the threads out of the aluminium.
Todo
Next I'll be painting the panel's inner side, cutting the screws down to size and putting the hole thing together
permanently.
Thanks for stopping by.
  #103
Old 29-05-13, 08:34 PM
mehere's Avatar
mehere mehere is offline
OC3D Crew
that lacing look well sweet
__________________
build log
  #104
Old 30-05-13, 03:11 PM
OC3D Elite
Thanks!
Reservoir Modding
The Problem
A few years ago (probably ~2007) I bought this nice little reservoir for my Eheim 1046.
It's a very handy little thing, and it's built like a bloody tank (seriously, you could bludgeon
somebody to death with this).
However, back then Aquacomputer had not yet fully jumped on the G1/4" train and was still
using G1/8" in many of their products (as they had since their inception).
This requires a rather ugly and unwieldy adapter when wanting to use modern fittings, such
as the lovely blue Monsoon ones I've bought.
The adapter itself looks like this:
And with a fitting on it:
The Plan
Well, it's quite simple really: Retap the hole to G1/4". However, this would leave me with a
slight problem: Naked aluminium exposed to the coolant. I will be using a corrosion inhibitor
in my loop, but I want to reduce the chance for corrosion to ruin the party by painting over the
naked aluminium and sealing the hole thing against the coolant.
Disclaimer
I'm well aware of what galvanic corrosion is and how it works (well, I'm not a chemist, but I have
a better grasp of it than most people I'd say). I'm not saying that what you're about to bear witness
to is a good idea or something you should necessarily try yourself. It's an experiment. If it works,
great, if not, I haven't lost anything since I have no more use for the reservoir anyway. But don't
anybody start panicking about corrosion please. I'm aware of the risks, I've weighed them and
I've made an informed decision to go ahead.
Protecting the Insides
Obviously we don't want to crash into the opposing inner wall with our drill.
The Drill and Tap
The 11.80 mm drill bit with the G1/4" tap.
Improvising
The 11.80 didn't fit into the drill bit adapter, so I had to improvise a bit. The adapter actually
belongs to a Bosch pneumatic drill hammer, but that thing is way too powerful for this sort
of thing, so I decided to go with this configuration. It worked surprisingly well.
Naturally I didn't just drill the G1/8" to 11.80 mm, but first to 9 mm, 10 mm and then to
11.80 mm (a 11 mm drill bit would have been handy, 10 to 11.80 is a rather large step).
Lubrication
I didn't have any actual lubricant specifically for this, so I just used some of the gun lubricant I have
laying around (both for drilling and tapping the thread). Since it's made for the high speed movement
of a gun action, it works very well for this.
Tapping Hole
The 11.80 mm hole before threading.
Threading
And after cutting the thread. You can clearly see how thick the walls are on this thing. That's
why you need to lubricate very well. Otherwise the drill just blocks.
Test Fit
As expected, much better.
Protection
Alright then, let's paint that sucker! I did one coat of etch primer and two coats of paint.
Obviously I can't really do proper surface treatment within the thread, or put on too much
paint since it will just get stripped off by the fitting's thread anyway, but this should work
well enough to prevent the coolant from getting to the naked aluminium.
And on the inside:
Painted
The coat is pretty thick and has bonded nicely to the surface.
Done
The Monsoon fitting hides the paint job very well, and it goes in and out without
strippint the paint off the threads (there were two small patches of paint stripped
off, but I've covered those with the Humbrol enamel paint and things are nice and
sealed now).
As you can see, the reservoir has sustained the occasional scratch over the years.
  #105
Old 30-05-13, 08:53 PM
Mgutierrez33's Avatar
Mgutierrez33 Mgutierrez33 is offline
OC3D Crew
niiiiiiiiiiiiiice. Hope everything works out well with the repainted threads, that's a neat little res you got there.
__________________
Corsair Graphite 760T : Sabertooth 990FX R2.0 : FX 8350 @ 4.7 GHz : 8 GB Vengeance LP Low Voltage memory @ 2133 MHz : PowerColor AXR9 280X (1100 MHZ core, 1600 MHz mem) : Kingston HyperX 3K 240 GB SSD : Cooler Master Glacer 240L : Fractal Design Newton 800W PSU : NZXT Sentry 3 Fan Speed Controller
  #106
Old 30-05-13, 09:16 PM
OC3D Elite
Hehe, yeah I hope so too. If the experiment fails, I'll get over it. I have no other use for the
res anyway. But of course it would be awesome if things stayed trouble-free .
I've found a nice little vid of how they make this reservoir:
  #107
Old 31-05-13, 06:26 AM
mehere's Avatar
OC3D Crew
nice bit of kit that going to have to get one of them machines for my shed
__________________
build log
  #108
Old 31-05-13, 10:46 AM
OC3D Elite
My dream is to machine a pc case from a massive block of aluminium or steel (as in - take a
660 x 270 x 660 block and mill a case out of it).
Hilariously unrealistic, but maybe one day I can do that with a block of wood and some hand power
tools, that should be feasible.
Ah well, not that I can legitimately complain, my Caselabs ain't exactly something to sneeze at
either.
  #109
Old 31-05-13, 11:58 AM
sheroo's Avatar
sheroo sheroo is offline
OC3D Elite
Must admit, I did have to watch that vid all the way through - love things like that - very therapeutic.
Apparently my Grandad used to have a lathe in the shed, it was powered with a foot pedal.
__________________
"All his life has he looked away... to the future, to the horizon. Never his mind on where he was."
  #110
Old 31-05-13, 12:10 PM
OC3D Elite
I've watched that vid probably about a dozen times by now. So relaxing.
Although one of the most awesome milling vids I've ever come across is this one, milling
a helmet from a 120 kg block of solid alu:
I mean, seriously, that's just pure porn, especially when you have a look at the presentation
shots at the video's end.
*envy*
Tags
360 radiator, black and blue, fractal design r4, modding
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
