Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
Thread Tools Display Modes
  #1
Old 31-07-12, 08:09 AM
WooZ's Avatar
WooZ WooZ is offline
Newbie
Closed loop cooling. H80 or H60?
Hi I finally bought my new system but now i can't decide what cooler to go with.
From the beginning I was going to buy H80 but now I am thinking does I need H80 over H60 for 2500K 4.5-4.7 OC and H80 are 116$ but H60 78$.
My average ambient temperature is 22 degrees Celsius.
So does I need H80 over H60 in push\pull? Is couple degrees worth 38$?
__________________
Processor - 2500K
Motherboard - MSI Z77A-GD55
Graphic card - Asus GTX560ti Top
Memory - Patriot Viper 3 1600MHz 8gb
Storage - Crucial M4 64gb and Seagate 320gb
Cooling - Noctua NH-D14
Power supply - Corsair GS600
Case - Fractal Design Define R3
  #2
Old 31-07-12, 08:59 AM
Kyze's Avatar
Kyze Kyze is offline
Member
If youre aiming for 4.7GHz id go for the H80.
Are you set on the Hydros? No Aircooling in the back of your mind?
__________________
My Rig in the Gallery!
  #3
Old 31-07-12, 09:07 AM
WooZ's Avatar
Newbie
No. Because I have windowed case and air cooler like NH-D14 cover most of the motherboard.
I am ready to spend more for aesthetics.
__________________
Processor - 2500K
  #4
Old 31-07-12, 09:10 AM
Kyze's Avatar
Member
Alright then, like said my vote goes for the H80 with the overclock youre going for.
Your ears wont have fun with the H60 at higher load
__________________
  #5
Old 31-07-12, 09:26 AM
WooZ's Avatar
Newbie
Or maybe i would go with Antec 920 it is little bit cheaper than H80. But both perform very similar.
__________________
Processor - 2500K
  #6
Old 31-07-12, 09:41 AM
airdeano airdeano is offline
OC3D Elite
to equal or surpass the D14 in performance.. neither the H60 or H80 are contenders..
ive run both along with the H50 and H70.. for evaluation and hands-down against the D14
none are even close enough to consider. only the H100 was close with temperatures but the noise
was rotten.
swapped the fans for a lot of different fans (noctua, corsair, artic cooling, silverstone, cooler
master, scythe, bgears, delta, swiftech) .
IMO.. skip the H60/80 and use the H100. note all the comparo to NH-D14 and the H100.
not really many comparos to the H60/80.
airdeano
  #7
Old 31-07-12, 10:00 AM
WooZ's Avatar
Newbie
was rotten.
airdeano
My case does not support H100. And I don't want cooling solution equal to NH-D14 but i just want stable 4.5-4.7 oc
__________________
Processor - 2500K
  #8
Old 31-07-12, 02:02 PM
Josh Weston Josh Weston is offline
OC3D Elite
A H80 should be fine for 4.5GHz on a 2500k.
Tags
2500k, h60, h80
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
