Go Back   OC3D Forums > [OC3D] Customer Care Forums > Aquatuning Customer Care
Thread Tools Display Modes
  #1
Old 27-01-16, 11:05 AM
Aquatuning's Avatar
Aquatuning Aquatuning is offline
Member
NEW: Alphacool antistatic mat Eisplateau
Alphacool Eisplateau
We have the perfect pad for modding and crafting especially for you The Eisplateau is an antistatic mat which has an appropriate wristband included. With a size of 120x60cm you’ll have more than enough space for your projects. All connections, radiators, fans and pumps are additionally depicted at a scale of 1:1. We even added a printed measure tape at the bottom of the mat if by any chance you have lost or “relocated“ your folding ruler.
Now available in our shops
  #2
Old 27-01-16, 11:23 AM
tinytomlogan's Avatar
The Guvnor
Can the metal bits for the wristband be removed?
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #3
Old 27-01-16, 11:36 AM
Aquatuning's Avatar
Member
Yes you can, it`s very easy to remove them.
That is the backside:
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
