Go Back   OC3D Forums > [OC3D] Customer Care Forums > NZXT Forum
  #1
Old 05-01-16, 08:35 PM
ImNotLucci ImNotLucci is offline
Newbie
Question NZXT Noctis 450 Fan hub
Hello,
I own a noctis 450 since a couple weeks and I don't know if its a build problem or just me but here is what i'm experiencing : everytime I turn my PC on, the case fans are at their minimum speed until windows loads and then go full speed.
To reduce the speed I have to do it manualy (via MSI Command Center, I've got a msi mobo).
The hub is powered by the MOLEX connector and controled by the PWM connector connected to one of my CPUFAN connector on the mobo.
So does it seem normal or is there an issue ?
Thanks,
ImNotLucci
  #2
Old 05-01-16, 08:37 PM
tinytomlogan's Avatar
The Guvnor
Sounds like a config issue on the motherboard to me
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #3
Old 05-01-16, 08:43 PM
Newbie
I also forgot to mention that I can control the fans but I can not see their speed as if they were not detected by the system. The hub is connected to the CPUFAN2 connector and my CPU fan (cooler master evo 212) is connected to the CPUFAN1 connector and he is working properly (speed speed in function of CPU temperature and is detected). Tried to invert the connectors but did not change anything.
  #4
Old 05-01-16, 08:46 PM
CreatiXx's Avatar
CreatiXx CreatiXx is offline
Advanced Member
Try another connection instead of CPUFAN and check out if it gives any difference
EDIT : what i found on another source, this might help maybe?
"The PWM cable coming off the hub will go to the CPU_FAN header. You can directly connect the CPU_FAN device to the PWM Hub as well"
__________________
i7 6700k | Jonsbo CR-201 Red | MSI Z170I Gaming Pro AC | G.Skill Trident Z 16GB DDR4-3600 | MSI R9 390 | Samsung 850 EVO 500GB | Fractal Design Nano S | Sharkoon WPM 700
  #5
Old 05-01-16, 08:49 PM
Newbie
Already did that, still had the problem :/
Posts merged - Please do not post multiple times in a row
The "CPU_FAN header" is one of the CPUFAN connectors on the motherboard, right ?
  #6
Old 05-01-16, 08:54 PM
CreatiXx's Avatar
Advanced Member
yes it is
Now that behind, all this doesnt seem that bad though, might be some strange windows settings thats puts it all at 100% as default. It is connected on a molex after all ^^
if it really disturbs you, you can always buy another fancontroller that you can build in and control without software
__________________
  #7
Old 05-01-16, 09:29 PM
Newbie
Well command center should be controling them but they won't listen
  #8
Old 24-02-16, 07:23 PM
ASGard ASGard is offline
Newbie
The NZXT PWM fan hub is a strange device indeed. I have a new version of the H440 with this hub and my testing has shown the following........
1. No need to connect the PWM cable to the CPU header on your motherboard, connecting to any controllable fan header works the same.
2. You must have a case fan connected to the white fan connector on the hub (fan1) to see rpm of the fan but this only shows the rpm of the connected fan on that particular header.
3. Changing fan speeds via the motherboard BIOS or software only affects the fan on the white fan1 header, all other fans appear to run at full speed.
Basically the fan hub is rubbish.
  #9
Old 06-03-16, 02:04 PM
Soul7 Soul7 is offline
Newbie
Same porblem with noctis 450.Any solution?
  #10
Old 18-03-16, 11:33 PM
Dave2017 Dave2017 is offline
Newbie
hi tom
ill be using the noctis 450 with the x61 kracken for my 1st build, am I able to connect the x61 kracken to the fan hub then connect the fan hub to the cpu header on the motherboard ( ga-z170xp-sli) ?
I'm presuming by doing this I would be to moniter the temps from the x61 and the case temps from case fans using cam software ? also does the cam software allow me to moniter the gpu temps (gtx 980 ti) aswell or do I need to use the nivida software for that ?
many thanks in advance,looking forward to my 1st build
Tags
fan hub, noctis 450, nzxt
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
