Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
View Poll Results: Which AIO should I get?
Corsair H105 12 66.67%
NZXT Kraken X60 1 5.56%
Other 5 27.78%
Voters: 18. You may not vote on this poll
  #1
Old 17-05-14, 12:44 PM
.Niar .Niar is offline
Newbie
Which AIO?
Hey,
for my new rig I'll be using an AIO for the CPU but I just can't decide which one to get.
I really like the H105 from Corsair because of it's thickness but I don't really like the look of the pump (with that colored ring). I also considered the Kraken X60 from NZXT as an option but heard that the pump is not that good (makes strange noises) but it looks soooo good (call me shallow but looks are very important to me).
So what do you guys think, which one should I get?
  #2
Old 17-05-14, 01:20 PM
Vanner's Avatar
Vanner Vanner is offline
Newbie
I would like to say the H100i as that is what like to recommend (best look and great cooling personally) and depends on much over-clocking you want to go for. I think looks matter a lot, if it is not right it will just bug you for the next few years you have it sitting in your computer. All dual rad AIO a very good just think what you rate higher, greater over-clocking or looks. It also depends if you are running heavy cpu programs and need that over-clock to be maxed out or not.
  #3
Old 17-05-14, 01:37 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
Originally Posted by .Niar View Post
Hey,
Firstly which CPU are you using? Secondly will you be overclocking?
If your not overclocking you could always go for the H75 the pump is the same as the H105, and the H105 is overkill if your not clocking it.
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #4
Old 17-05-14, 02:46 PM
Newbie
I'll be going for and FX8350 and I'll be trying to overclock as much as possible
  #5
Old 17-05-14, 02:52 PM
Macroman595's Avatar
Macroman595 Macroman595 is offline
Newbie
Send a message via MSN to Macroman595
The Guvnor himself has done various reviews on CPU coolers. Search H100i and you will find it.
TTL also mentions a bundle you can get from special tech. Cooler and fans.
__________________
Asus P8Z77-V LX (not overclocked), Intel i5-3450 @ 3.10GHz (Ivybridge), 8gb 2x4gb Kingston HyperX blue, XFX 7870 Tahiti LE, Samsung 840 pro series (OS, boot drive etc), Seagate Barracuda 1.5TB (Mass storage), Corsair TX650, Windows 7 Home Premium 64 bit
  #6
Old 17-05-14, 02:54 PM
Newbie
I know, but I can't really which one to get so I just wanted to hear some opinions
  #7
Old 17-05-14, 03:00 PM
Vanner's Avatar
Newbie
I will say it again, I would get the H100i, very good, looks good, and get 2 sp120 perf if you want temps down and then you change the rings to your colours and will look great in any system. Still get a brilliant over-clock and look sexy. Will get your temps down loads as still a dual AIO.
  #8
Old 17-05-14, 03:05 PM
Newbie
Sounds good to me, but I'll keep waiting a bit for other suggestions
  #9
Old 17-05-14, 03:22 PM
MacLeod's Avatar
MacLeod MacLeod is offline
OC3D Elite
Im using a H100 on my 8150 and its working great. Im at 4.5 GHz @ 1.39V and its good enough that I can keep it on low fan setting and it keeps my CPU in the low to mid 40's during gaming. The H100i is a marginally better cooler so I would second Vanner's suggestion for it based on my own experience which has been very good.
__________________
AMD Ryzen 7 3700X ••• Asus ROG Strix X370-F ••• Corsair H110i
Corsair 500R ••• EVGA Supernova G3 750 ••• Corsair Vengeance 32GB
Western Digital Caviar Black 1TB x2 ••• Asus Strix RTX 3070
Samsung 840 Evo 250GB ••• Acer Predator XB273
Corsair K70 TKL Champion Series ••• Razer DeathAdder Elite
  #10
Old 17-05-14, 03:26 PM
barnsley's Avatar
barnsley barnsley is offline
born in a.....
If you want to really overclock an 8350 to its very limit a h105 would be a good bet. IMO a swiftech H320 would have been perfect but they're a pain to get hold of.
You want a thick rad and decent fans. Thats my experience of a FX9590, which is basically a maxxed out 8350 . It started off with a h100i but the guy wanted quiet so he ended up getting a noctua NH-D14 cooler.
__________________
Rig: i7 [email protected]|2x8gb HyperX Fury|Intel z97-AR|Corsair H75| 2x Nvidia 1070 founders edition|Superflower leadex 750W gold|Inwin 904| 970 EVO 500GB m.2|512GB evo 840| Crucial MX 500 500GB|ASUS MG279Q +Acer S240HL| Windows 10 pro, 8.1 pro| Kubuntu LTS
Audio: Silverstone EB01-E+EB03+DT 770 Pro 250Ω+Samson SAGOMIC
Ducky Legend (cherry red)+Zowie AM-FG
Tags
corsair, h105, kraken x60, nzxt
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
