Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #1
Old 31-12-17, 09:56 AM
chris_86 chris_86 is offline
Newbie
Corsair braided cable size for combs?
Hi - I've recently bought some Type 4 / Gen 3 braided cables from Corsair, which you can see here:
http://www.corsair.com/en-gb/premium...-3-white-black
The part number is CP-8920149
My question is this: what size cable combs do I need for them? They came with a couple but they are difficult to measure.
I have the following choices of size:
2mm
3mm
4mm
I'm amazed this information isn't on the product description - it should be because people like to plan their builds! If anyone can help I'd be suitably grateful!
  #2
Old 31-12-17, 01:33 PM
Korreborg's Avatar
Korreborg Korreborg is offline
OC3D Crew
4mm for the 24pin cable, and 3mm for the rest. I measured my pci cable and ordered 3mm combs, and I cannot force the 24pin cable into them, without breaking the comb.
__________________
[I9-7900X][Asus Strix X299-E][EVGA 1080TI FE][Corsair 16GB 3733MHz][Fractal Meshify C][Corsair AX860i]
[Samsung 970evo 500GB+1000GB of mixed SATA SDD's][ASUS PG278QR][Logitech G510s and G502][Steelseries Wireless H]
  #3
Old 01-01-18, 02:20 PM
Newbie
Cheers, I will try a 3mm kit then and perhaps course some other combs for the 24-pin if needed.
Tags
braided, cable comb, corsair, size
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
