Go Back   OC3D Forums > [OC3D] General Forums > OC3D Reviews & Videos
Thread Tools Display Modes
  #11
Old 21-11-18, 02:56 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
I will take worst case scenario reviews over buttered up *any* day thanks. That is why I am still bloody here !
__________________
"Those really high 20 series prices are just place holders"
  #12
Old 21-11-18, 03:03 PM
Warchild Warchild is online now
OC3D Elite
Originally Posted by MacLeod View Post
I think it's proper to test GPU's on a games most demanding sections. There are sections in Crysis 3 that my old 290x could get 80-100 fps at max settings... Then there were entire sections where it would be in the 40's.
I would rather a review show me the worst case scenario. If a review shows me I can get 60 fps with a 1070 at 1440, if it's tested in the most demanding sections then I know that I can expect 60 fps anywhere in that game. If the review is based on an easy section then I'm gonna find myself pausing the game in order to change settings cause I'm crawling thru at 30 fps in the most demanding parts of the game.
Actually I prefer a balance. If a good game has my interest and I see only the worst section which lets say last 30sec. I could assume the whole game is like this and would put me off purchasing.
if the rest of the content was in the 100s, but I knew of small areas where fps tanked. I could forgive those moments and still make the purchase. It is good to see worst case, but there should be a balanced approach.
__________________
  #13
Old 21-11-18, 04:25 PM
WYP's Avatar
WYP WYP is offline
News Guru
There is a balance to be had here and it is something that would need to be considered on a game-by-game basis.
For example, the recent Dragon Quest had tonnes of specific areas where even a GTX 1080 would dip below 60 FPS, while most game locations would allow even a GTX 1060 to achieve to sit at the game's 60FPS cap. In that case, I mentioned the dip areas in the text of the review and commented that the results and benchmarking location that I used are representative of what if a demanding area but not the game's worst case scenario.
In the case of Hitman 2, I tested the game using two benchmarking locations, one which is CPU heavy and another that is GPU heavy. The GPU heavy scene I used is very hard on Radeon GPUs, but it isn't exactly "if I look at this area just right the framerate tanks" or a "if I intentionally do this to try and make the game chugg" kinda situation. It's just how that level plays.
I have had a look at some other performance analysis pieces on Hitman 2 and it seems that Digital Foundry has spotted the same problems, as they seem to have played the game to the same mission as I have. I have also retested the RX Vega 56 at the same location and have received the same results as before.
I do plan to have a look at the new Simulation options that have been added to the game, and their impact on CPU performance. This will have to wait though, as my Church has midweek tonight.
__________________
One of these days I'll change my name to Mark Bench
  #14
Old 21-11-18, 04:47 PM
OC3D Elite
Dont think too much into my comment. You have done nothing wrong here in Hitman. I was just stating in general, it is good to present the reviews with an overall approach. Majority of us here already have an idea of how a gpu would cope.
__________________
  #15
Old 21-11-18, 05:25 PM
WYP's Avatar
WYP WYP is offline
News Guru
My thoughts were not really directed at you, more just getting some ideas out there so that people can better understand my perspective.
__________________
  #16
Old 21-11-18, 06:36 PM
kardeon kardeon is offline
Newbie
Thanks for your answer. I do understand your point of view and effectively Hitman 2 is not easy to benchmark because of the disparity of each level
  #17
Old 21-11-18, 06:42 PM
BFBC2033 BFBC2033 is offline
Newbie
Originally Posted by NeverBackDown View Post
It all depends on the mission. Reviews have never been apples to apples even with the same hardware. Not sure why you expect anything else?
As I played the first Hitman, there were no major performance differences between all the mission, so I would assume the same for this one. And for the reviews, thats simply not true. Nearly all big reviewers get around the same performance indications in big titels (This does of course not mean the same numbers but behaviour). It is queit unusual to see such a variance.
As for the pictures they are so irrelevant that to assume it makes an article untrustworthy is to me quite childish that it bothers someone. I only mention this because you come off as an AMD guy who is upset the vega 56 and the cover article photo both show AMD falling behind.
Could you please read properly what I wrote. I never said that this review is untrustworthy, I wrote an idiom the showcase my problem with such fanboyish memes. Also this is a game review not a hardware review, its about how the game performs, not the hardware (to be more precise, a game review does not show the hardware performance, it shows the software performance, since you already know from proper benchmarks how your hardware should perform.).
I mean we already know a Vega 56 is slower than a 1070ti, so I again don't know why you expect anything else mate?
Again you deliberetly misrepresent what I said. I quoted the performance from hw's review. I even said myself that this is a bit high. I never implied or said that the vega 56 is generally faster than an 1070ti so why imply it.
Food for thought, maybe Steve's results are a bit off and not WYPs? I would be more suspect a 1070ti lost a Vega 56 than anything.
Not attacking you. Just curious as to why you think the review was bad when it honestly is one of the very few performance reviews on the internet that I found. I looked around as you suggested and found just this article. Nothing else comparing really anything(outside of consoles from Digital Foundry).
The reason why I asked WYP is because in his test every Radeon GPU performed bad, not only a few. Also the likelihood of getting an answer from him than steve is way higher.
After reading the other replies I got a good picture of how things come together. I appreciate WYP insight on his testing methodology and thoughts behind it.
  #18
Old 21-11-18, 07:37 PM
MacLeod's Avatar
MacLeod MacLeod is offline
OC3D Elite
Testing methodology aside, how is the game? I'm always in the market for a good single player action game like this. They're not making my all time favorites Batman and Dead Space. I didn't care much for Absolution tho, a little too much slow crawling and stealthing and not enough action. Is this one any better?
__________________
AMD R5 1600X @ 4.0 GHz ••• Asus ROG Strix X370-F ••• Corsair H110i
Corsair 500R ••• EVGA Supernova G3 750 ••• Corsair Vengeance 16GB
Western Digital Caviar Black 1TB x2 ••• Nvidia RTX 2070 FE
Samsung 840 Evo 250GB ••• BenQ XL2720Z @ 1080
Logitech G-Pro TKL ••• Razer DeathAdder Elite
  #19
Old 21-11-18, 10:23 PM
WYP's Avatar
WYP WYP is offline
News Guru
I've enjoyed it. The overarching story is a bit "eh" but I have enjoyed the sandbox assassination action. There is a free trial version that you can try out, which will give you the prologue mission. It should give you an idea of what to expect.
Hitman 2 isn't really an action game, as stealth and quietly taking out targets is the goal. Agent 47 isn't great in long gunfights. The aim of the game is to search the map and discover ways to take out your target, whether it be discretely or otherwise.
It's a fun game if you want to walk around and consider every way of taking out your target, but I wouldn't describe it as action.
__________________
  #20
Old 21-11-18, 11:49 PM
MacLeod's Avatar
OC3D Elite
Hmmm.... Well I'll probably skip it then. I don't have the attention span to handle games like that... I need some shooting and explosions lol
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
