Thread Tools Display Modes
  #401
Old 07-09-15, 05:42 AM
Feronix's Avatar
Feronix Feronix is offline
OC3D Elite
Oooohhhh now I like it a lot more already!
__________________
~Rick
"If a bear looks good in the woods when nobody is there, is he still a cool ass motherf***ing bear?" - JR23
  #402
Old 07-09-15, 05:52 PM
alpenwasser's Avatar
alpenwasser alpenwasser is offline
OC3D Elite
He, thanks!
Small amendment: This is the concept for the copper tubing I came up with: Take a 16 mm OD/12 mm ID pipe, cut a G1/4" thread into it, screw fitting in, done. Works very well, you just need to make sure you have a clean cut so that the fitting's O ring can seal against the pipe.
These are from a test I did to see how well it works:
What I like about the concept is that you don't get any bulky fittings, the pipes are pretty much the same diameter as the fittings. Downside is that you can't really bend 16/12 tubing, so you have to use tons of dual-rotary, dual-male threaded angles. And unfortunately, only Bitspower seems to be making these (or at least I've only found them from BP), which is why it would (will? ) be so expensive.
Still, some day maybe...
  #403
Old 07-09-15, 07:25 PM
Mysterae's Avatar
Mysterae Mysterae is offline
OC3D Crew
Looking good Alpenwasser!
I do like your idea on the fittings for the 16mm pipe, make it so!
  #404
Old 08-09-15, 01:02 PM
OC3D Elite
Hehe, as soon as I win the lottery!
Tags
560 radiator, caselabs smh10, copper, evga sr-2, geforce titan
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
