Thread Tools Display Modes
  #101
Old 30-04-13, 03:19 PM
alienware alienware is offline
Banned
Send a message via MSN to alienware
Originally Posted by JMMP View Post
Hi alpenwasser!!
Out of curiosity, do you know that HELIOS it´s the name of Bull´s Supercomputer?
I just wanted to share this information with you!
by the way.....nice rig you´ve got there
http://www.datacenterdynamics.com/fo...s-comes-online
It's also in Fallout : New Vegas and linked with Archimedes Death Ray
Well, strictly speaking the location is called Helios one.
  #102
Old 30-04-13, 04:00 PM
alpenwasser's Avatar
alpenwasser alpenwasser is offline
OC3D Elite
Hi alpenwasser!!
Haha, I did not know that, thanks! The original HELIOS (~2001) was actually called that because
I was (and still am) a huge fan of the original Deus Ex, in which an entity with that name is
of rather high importance to the plot. And also, I've always been fascinated by ancient
Greek mythology.
Always good to learn new stuff.
GENERAL UPDATE, as long as I'm writing posts anyway
I have been contemplating cable management and cable routing in the past week (besides
working on ZEUS, which is a bit more urgent tbh). I'm pretty sure I will need to do some
custom cables to get this to look tidy, which means I have to order some equipment for that,
so it might take me two weeks or so until things for HELIOS make some more serious
progress. But I'd rather do this right and have it take a while longer than get shoddy.
In the meantime, I might investigate how to get the best bending results for the copper
pipes. I can't really use a standard pipe bender since 15 mm benders have a bit high
bending radii for this to work, so I will need to devise a custom contraption, probably.
Also, 15 mm benders are quite expensive (at least the ones I've found so far), especially
with shipping included.
I will let you know about my conclusions, nothing has been decided yet. Now, time for
some Iron Man 3
  #103
Old 30-04-13, 04:10 PM
pcjunkie429's Avatar
pcjunkie429 pcjunkie429 is offline
Member
Bench vise + blowtorch = ?
some Iron Man 3
Dang you Europeans (and pretty much everyone else in the world) for getting to see it first! (jk )
I have to wait till Friday (May 3) to go see it
__________________
NOT Lee Harrington (owner of PCJunkie Mods), just a fan of his.
PC Specs (as of 4/15/2013): AMD FX 8150 (OC to 3.87 GHz using AMD Asetek AIO Liquid Cooler), 8gb of Kingston HyperX Black Edition 1600 MHz DDR3 RAM, Sapphire Vapor-X AMD Radeon 7770 GHz Edition, WD Caviar Blue 500GB, SeaSonic X Series 600w PSU, Zalman Z12 Plus case
  #104
Old 30-04-13, 06:09 PM
AverageNinja's Avatar
AverageNinja AverageNinja is offline
Average Penis Too
I demand pictures of the system!
That's what build logs are all about (for me atleast)
__________________
JavaBean: Ryzen 5 1600 / Corsair ML240L RGB / ASUS Crosshair 6 Hero / 16GB Corsair LPX / ASUS RX 580 Strix / Corsair RM750X / Fractal Design Meshify C
OC3D Overclockers Club Member:
Nr. #00 (Club Owner)
  #105
Old 30-04-13, 10:10 PM
OC3D Elite
Hm. Why not?
Welll, the good news is: It's, really, really good (at least imho).
I shall see what I can do tomorrow
  #106
Old 30-04-13, 11:13 PM
AMD Enthusiast
Pics or it didn't happen!
__________________
I am Iron Man.
  #107
Old 02-05-13, 06:03 PM
OC3D Elite
Status Update - Wiring
Status Update
Just a quick status update: I have placed an order for some crimping stuff at Lutro0 customs,
which I will need to make the custom wiring. His crimper is a bit more suited to crimping
connectors onto 16 AWG wire (which the Enermax uses for most of its connections) than the
one from MDPC-X, which is why I went to Lutro0's even though Germany would be a lot closer
to where I live
Aside from that I've also ordered some Silicone wire in 16 AWG, 18 AWG and 20 AWG from
a British shop for making completely new cables. And just to avoid misunderstandings:
That's Silicone, not Silicon.
For those not familiar with the awesomeness of Silicone wires, they have basically two main
advantages over the normal PVC insulation wires (if they are of good quality, of course there is
also lesser quality Silicone wire): They are more resistant to chemicals and heat (the one I've
ordered can be used continuously at 200 C) and they are ridiculously flexible. The
downside is that they are a lot more expensive and that they are ridiculously flexible (since that
can also be a disadvantage if you're trying to get your cables to look neat and stay where they
have been placed). Also, they smell funny when they come out of the packaging.
I will probably make a Youtube demo vid to demonstrate the flexibility, it's really an enormous
difference. As for the heat and chemical resistance thing, that's neat and all but of course I
hope not to have to test those parameters in my build. The main reason I'm spending so much
money on wires is their flexibility and the quality.
Making completely new cables will also spare me from having to destroy some of the PSU
stock cables. I will have to reuse some of the connectors for the PSU modular PCB, but I
won't have to destroy the cables and if I ever have a problem with the PSU I can just pop the
connectors back onto the stock wiring and RMA the unit.
Until that stuff is here I will be experimenting on getting those Raystorms to a mirror shine,
which is a lot of work but unfortunately does not make for a very exciting build log section.
So yes, the prime directive for now is patience, but I'd rather wait a little bit longer and have
it turn out exactly as I want it to than start to get shoddy now.
Thank you for your attention.
  #108
Old 03-05-13, 12:14 AM
AMD Enthusiast
Please do a vid! Would love to see the difference in cabling. Since it's new to me and not just a change in color
__________________
I am Iron Man.
  #109
Old 03-05-13, 05:33 AM
da axxxe's Avatar
da axxxe da axxxe is offline
Newbie
dam would also like to see a video on the wires ,this build gets more and more intense every time i look at it .would you recommend doing this to a brand new power supply was gonna simply sleeve the standard cables butt after reading your wiring update think might do something along these lines as well
__________________
  #110
Old 03-05-13, 12:37 PM
OC3D Elite
Ok, I'll see what I can do. But first I have to get the parts.
I would say it depends a bit. For one thing, the Platimax is a very expensive PSU, so not
breaking warranty is a nice bonus. It's also 100% modular, which makes this a bit easier.
For a non-modular PSU you can either sleeve and shorten the original wires (which will
definitely break the warranty, especially if you open the unit), or make some custom
extensions (which might lead to clutter, since you will have a lot of extra cable length to
hide) or a combination of the two. I am currently working on that problem for ZEUS, but
I'm not satisfied yet with the results, hence no update.
But for a 100% modular PSU I think this is a pretty good decision. Besides not breaking
the warranty you can make the wires exactly as long as you need them to be. Of course
you could also shorten the stock wires (or make extensions), but then you'd need the
exact same tools you'd need to make completely new ones. So to me, spending a little
bit extra on connectors and some additional wire is worth it. You don't have to go for
Silicone wire, normal PVC wire is a lot cheaper, so it's not like making completely new
cables will necessarily cost you a lot more than reusing the stock ones.
Tags
560 radiator, caselabs smh10, copper, evga sr-2, geforce titan
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
