Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #1
Old 16-01-14, 09:53 AM
Tiki Tiki is offline
Newbie
GA-990FXA-UD3 Northbridge heatsink replacement
I am set on changing the NB HS in my UD3, but I can't find a one that clearly says is compatible.
Could anyone please tell me of one that fits properly (as in you know for a fact that it does), I have only one shot at it since I'm buying it from USA via a friend so I can't afford getting one that won't fit. Also, is it worth replacing the VRM HS too? Thanks in advance.
__________________
Phenom II 965 @ 3.8GHz 1.392v; NB @ 2400MHz 1.200v
Cooler Master Hyper 212+
Gigabyte GA-990FXA-UD3 rev 1.1 (F9)
XFX Radeon HD 5770 @ 915/1300 1.025v
G.Skill RipjawsX 2x4GB @ 1600MHz 9-9-9-26-33 2T 1.500v
Intel SSD 320 40GB & WD Caviar Black 1002FAEX
Corsair TX850M / Corsair 400R / Acer S232HL Abid
  #2
Old 16-01-14, 09:59 AM
tinytomlogan's Avatar
The Guvnor
Might have helped if you posted a photo
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #3
Old 16-01-14, 10:27 AM
NickOmega's Avatar
NickOmega NickOmega is offline
OC3D Crew
The only way you'll find out for sure what will fit is to measure the distance between the 2 mounting points on the board, and take into account the size of your CPU cooler.
As for the VRM heatsink, this is reported to fit the UD3.
__________________
My Twitch Channel
Ryzen 5 2600X -- EVGA GTX 1070 SC -- 16GB TeamGroup Dark Pro 3200mhz DDR4
MSI B450 Gaming Pro Carbon -- Corsair Force MP300 240GB
Seasonic Focus Gold 750 -- Phanteks P350X
  #4
Old 16-01-14, 01:31 PM
The Guvnor
They and find a faulty UD5 on ebay maybe? Might need a bit of dremmel work but people dont generally bother with replacing heatinks anymore.
Are you having huge heat problems?
__________________
  #5
Old 16-01-14, 03:13 PM
Newbie
Sorry about the picture bit Tom and thanks Alcoholocaust for providing them.
Yes I'm having quite a bit of heat problems. It is an issue on the UD3's from rev 1.0, 1.1, 1.2 and 3, it was only fixed at rev 4. Right now we are on a really hot summer with temps of 30c to 40c, so even at stock the NB gets to 58-62C while gaming. Can't even OC because if i do, it easily can past over 70c and is not a faulty read from the sensor, it literally burns my fingers if I touch the heatsink.
I have removed the crappy pink bubble gum that Gigabyte calls thermal paste and replaced it with MX-2 which lowered the temps by almost 20c, back when I first got the Motherboard it was reaching 80c, which by the way, Gigabyte so-called "tech support" says is fine and it can even go up to 100c.
__________________
  #6
Old 16-01-14, 03:38 PM
NickOmega's Avatar
OC3D Crew
No problem mate.
I have the same board (Rev: 3.0) and I confirm the NB heatsink gets ridiculously hot, to the point it burns your fingers to touch it for more than a couple of seconds. I haven't changed the thermal materials on mine as I've gone on the assumption that if the heatsink is hot then the paste/tape is doing it's job of transferring the heat, might have to try it myself and see though.
The aftermarket cooler may also contribute to the higher temperature as the stock fan/HS would be moving air across the NB and VRM heatsinks.
__________________
My Twitch Channel
  #7
Old 16-01-14, 04:31 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
Tiki which CPU cooler do you use? I found my GA-78LMT-USB3 NB gets seriously hot while gaming ever since I took away my Topdown fan cooler and switched it for a AIO Cooler Master Seidon
This was my old cooler which chilled my bridges lovely
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #8
Old 16-01-14, 04:33 PM
The Guvnor
This could be an option too then (my choice for face down cooler just dont use the 92mm fan at all)
Review: http://www.overclock3d.net/articles/...h-l12_review/1
__________________
  #9
Old 16-01-14, 04:39 PM
Wraith's Avatar
Bettyswollocks
Great option TTL! How about the Scythe Grand Kama? It has modding potential..
__________________
  #10
Old 16-01-14, 04:53 PM
The Guvnor
The Noctua above is the best facedown we have tested really matey.
That scythe isnt all that tbh
__________________
Tags
990fx, 990fxa, gigabyte, northbridge, ud3
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
