Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
Thread Tools Display Modes
  #1
Old 20-02-13, 05:15 PM
neblur neblur is offline
Newbie
Lightbulb Corsair H100i Screws?
Hi there i am going to be building quite a pricy rig in about 8 months and i will hopefully be using the h100i. Now i am aware that they only provide 8 screws for "2" fan's. I am lookign to mount it in a 900d hopefully in push pull so i ordered some screws today and what i want to know is if they will work?
The screws i ordered are http://www.chilledpc.co.uk/shop/prod...oducts_id=2036
Has anyone done a push pull config with a h100i yet? and if so could you link me to some screw's that you can confirm work 100% with the h100i or if the ones i ordered will work
  #2
Old 01-03-13, 12:00 AM
chris_61 chris_61 is offline
Newbie
Hi did you try these screws yet? i am also on the same boat and want to do push pull.
Chris.
  #3
Old 01-03-13, 12:23 AM
seumasbeathan seumasbeathan is offline
Banned
You are going to use a H100i in a 900D? That will look stupid IMO
Also, push-pull is pretty pointless
  #4
Old 01-03-13, 12:25 AM
Newbie
I have the 800D.
  #5
Old 01-03-13, 12:38 AM
Banned
Originally Posted by chris_61 View Post
I have the 800D.
I was referring to the OP
  #6
Old 01-03-13, 07:31 AM
SeekaX SeekaX is offline
OC3D Elite
900d + h100i?
money = wasted
either you go custom loop or you get a different case, it will look completely underspec'd
  #7
Old 01-03-13, 10:39 AM
Newbie
Don't take this the wrong way but he didn't ask your opinion on how it will look. Can we get back on topic, Do you know if the screws will fit or not? or where to get 8 of the long screws that corsair provide?
  #8
Old 01-03-13, 11:33 AM
tinytomlogan's Avatar
The Guvnor
two fans stacked will do noting. push pull is meant to be a set of fans on each side.
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #9
Old 01-03-13, 04:39 PM
Newbie
Who wants to stack the fans? Corsair does not provide long enough screws to do push pull and in the instruction booklet states that in order to do push pull you must buy additional screws on their website, However this is no where to be found.
  #10
Old 01-03-13, 04:46 PM
FTR.4500MHz's Avatar
FTR.4500MHz FTR.4500MHz is offline
OC3D Elite
For choosing the right screws you'll need to find out which threading was tapped into the h100i (M4, M3, 6-32, etc...).
Then the best lenght for 25mm fans in push/pull (bolted through the case) are 35mm screws. However if 35mm is too long you can always use some washers to avoid hitting the rad fins.
After that its up to you to choose colour, screw head print, shape etc...
I would suggest this:
http://www.specialtech.co.uk/spshop/...pid-14509.html
__________________
Hardware: Shinobi XL w.custom window | Msi Z77A-GD65 | i5 3570k | 8GB Corsair Vengeance 1600MHz | 7970 Lightning BE | AX 850 | SSD's: Samsung 830 128GB , Corsair Force GT 120 GB | HDD: Seagate Barracuda 750 GB | XonarD2X | Edifier S730 | iiyama prolite g2773hs-gb1 |
Watercooling: EK supremacy p/n | EK 7970Ltg. a/n | D5+EK Top | UT60 360 and 240 rads | EK X3 150 res. | Tygon 13/19mm | Bitspower C.fittings |
Tags
corsair h100, h110i, radiator, screw, watercooling
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
