Thread Tools Display Modes
  #61
Old 13-04-14, 05:20 PM
Bartacus Bartacus is online now
OC3D Elite
Originally Posted by MadMarc View Post
Amazing how you managed to get even this amount of bright red cables looking tidy
THIS!! Fantastic job of doing that so neatly without custom length cables!
P.S. all that redundancy and only a single drive for the OS? Shame, shame.
__________________
Guts: ThreadRipper 2950X / GB Aorus Xtreme X399 / 64GB TridentZ Royal 3600CL16 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU
Storage: 6TB RAID0 NVME array (ADATA SX8200 Pro 2TB x 3)
Water Cooling: HeatKiller TR4-Pro CPU block / HeatKiller IV GPU blocks / 360mm Darskide LP360 rads x 3 / Heatkiller reservoir
  #62
Old 13-04-14, 06:00 PM
RadeonHDx RadeonHDx is offline
OC3D Elite
That really is the definition of third time's the charm , looks so tidy, makes me feel slightly ashamed of my cables now .
__________________
Intel Xeon E5649 x2 | Custom Water Loop
Saphire R9 290 Tri-X Edition | InWin Dragon Rider White
24GB Samsung RAM | SuperMicro X8DTi R2.0
Samsung Evo 250GB | 1TB Hitachi HDD
  #63
Old 13-04-14, 06:58 PM
alpenwasser's Avatar
alpenwasser alpenwasser is offline
OC3D Elite
Haha, yeah custom length SAS/SATA cables, that would really be something!
And thanks!
Hehe, it will be backed up to the Velociraptor (just haven't built it in yet),
but in the end the host OS isn't that important, the important things are
the virtual machines (which will be backed up). So basically, if the SSD fails,
I can just get a new one, do a clean install (which can be done very quickly
because it's a very basic setup), copy-paste the VMs and I'm back up and
running again.
I'll probably get another SSD for HELIOS at some point, then I'll use the one
I have in there now as a spare for APOLLO.
EDIT:
I should probably mention that having a bit of downtime is not a huge deal
on this machine as long as it's not too long (like, a few hours). Otherwise I
would have RAID1-ed the OS drive, of course. But in an emergency I can always
use the Velociraptor as a temporary system disk, since I have it laying around
anyway. Until I get another SSD that will be adequate.
/EDIT
Haha, yup it is indeed, thanks!
I recommend you get to work on your cables then!
  #64
Old 14-04-14, 06:56 AM
JayCobs's Avatar
JayCobs JayCobs is offline
Member
Location: Where it's hot in the summer and cold in the winter
The grill-less heat sink fan is makin' me anxious!!! LOL
__________________
Preventively pessimistic.
Projekt Suma Kuhl 2013 (ended)
http://forum.overclock3d.net/showthr...Suma+Kuhl+2013
Tha Leviathan build in progress...
http://forum.overclock3d.net/showthread.php?t=56390
  #65
Old 14-04-14, 11:05 AM
OC3D Elite
Haha, yeahI thought about mounting grills to the fans (especially those
high-rpm ones in the middle wall), but all the cables are pretty taught and
don't go anywhere, so it's not really an issue, and the machine won't be
opened while it's running, so there's no danger to anyone's fingers either.
  #66
Old 26-04-14, 11:37 PM
OC3D Elite
Storage and Networking Performance
Beware: This post will be of little interest to those
who are primarily in it for the physical side of
building. Instead, this update will be about the performance
and software side of things. So, lots of text, lots of
numbers.
These results are still somewhat preliminary since I'm not
yet 100% sure if the hardware config will remain like this
for an extended period of time (I really want to put another
12 GB of RAM in there, for example, and am considering
adding some SSD goodness to my ZFS pools), nor am I
necessarily done with tuning software parameters, but it
should give some idea of what performance I'm currently
getting.
As you may recall from my previous update, I'm running three
VMs on this machine, two of which are pretty much always on
(the media VM and my personal VM), and the third of which is
only active when I'm pulling a backup of my dad's work
machine (apollo-business).
NOTE: I know there's lots of text and stuff in my
screenshots and it may be a bit difficult to read. Click
on any image to get the full-res version for improved
legibility.
The storage setup has been revised somewhat since the last
update. I now have a mirrored ZFS pool in ZEUS for backing
up my dad's business data (so, in total his data is on six
HDDs, including the one in his work machine). His data is
pulled onto the apollo-business VM from his work machine,
and then pulled onto ZEUS. The fact that neither the
business VM nor ZEUS are online 24/7 (ZEUS is turned off
physically most of the time) should provide some decent
protection against most malheurs, the only thing I still
need to implement is a proper off-site backup plan (which
I will definitely do, in case of unforeseen disasters,
break-ins/theft and so on).
(click image for full res)
The Plan
For convenience's sake, I was planning on using NFS for
sharing data between the server and its various clients
on our network. Unfortunately, I was getting some rather
disappointing benchmarking results initially, with only ~60
MB/s to ~70 MB/s transfer speeds between machines.
Tools
I'm not really a storage benchmarking expert, and at the
moment I definitely don't have the time to become one, so
for benchmarking my storage I've used dd for the time
being. It's easy to use and is pretty much standard for
every Linux install. I thought about using other storage
benchmarks like Bonnie++ and FIO, and at some point I might
still do that, but for the time being dd will suffice for my
purposes.
For those not familiar with this: /dev/zero basically
serves as a data source for lots of zeroes, /dev/null is a
sink into which you can write data without it being written
to disk. So, if you want to do writing benchmarks to your
storage, you can grab data from /dev/zero without needing to
worry about a bottleneck on your data source side, and
/dev/null is the equivalent when you wish to do reading
benchmarks. To demonstrate this, I did a quick test below
directly from /dev/zero into /dev/null.
Basically. It's a bit of a simplification, but I hope it's
somewhat understandable.
Baseline
Before doing storage benchmarks across the network, we
should of course get a baseline for both the storage setup
itself as well as the network.
The base pipe from /dev/zero into /dev/null transfers has a
transfer speed of ~9 GB/s. Nothing unexpected, but it's a
quick test to do and I was curious about this:
For measuring this I used iperf, here's a screencap from one
of my test runs. The machine it's running on was my personal
VM.
Top to bottom:
- my dad's Windows 7 machine
- APOLLO host (Arch Linux)
- HELIOS (also Windows 7 for the time being, sadly)
- ZEUS (Arch Linux)
- My Laptop via WiFi (Arch Linux)
- APOLLO business VM (Arch Linux)
- APOLLO media VM
The bottom two results aren't really representative of
typical performance, usually it's ~920 Mbit/s to ~940
Mbit/s, But as with any setup, outliers happen.
The networking performance is where I hit my first hickup.
I failed to specify to the VM which networking driver it was
supposed to use, and the default one does not exactly have
stellar performance. It was an easy fix though, and with the
new settings I now get pretty much the same networking
performance across all my machines (except the Windows ones,
those are stuck at ~500 Mbit/s for some reason as you can
see above, but that's not hugely important to me at the
moment TBH).
This is representative of what I can get most of the time:
I had a similar issue with the storage subsystem at first,
the default parameters for caching were not very conducive
to high performance and resulted in some pretty bad results:
Once I fixed that though, much better, and sufficient to
saturate a gigabit networking connection.
Networking Benchmark Results
Initially, I got only around 60 MB/s for NFS, after that the
next plateau was somewhere between 75 MB/s and 80 MB/s, and
lastly, this is the current situation. I must say I find the
results to be slightly... peculiar. Pretty much everything
I've ever read says that NFS should offer better performance
than CIFS, and yet, for some reason, in many cases that was
not the result I got.
I'm not yet sure if I'll be going with NFS or CIFS in the
end to be honest. On one hand, CIFS does give my better
performance for the most part, but I have found NFS more
convenient to configure and use, and NFS' performance at
this point is decent enough for most of my purposes.
In general, I find the NFS results just rather weird
TBH. But they have been reproducible over different runs on
several days, so for the time being I'll accept them as what
I can get.
Anyway, behold the mother of all graphics!
FTP
As an alternative, I've also tried FTP , but results were
not really very satisfying. This is just a screenshot from
one test run, but it is representative of the various other
test runs I did:
ZFS Compression
Also, for those curious about ZFS' compression (which was
usually disabled in the above tests because zeroes are very
compressible and would therefore skew the benchmarks), I did
a quick test to compare writing zeroes to a ZFS pool with
and without compression.
This is CPU utilization without compression (the grey bars
are CPU time spent waiting for I/O, not actual work the CPU
is doing):
And this was the write speed for that specific test run:
With lz4 compression enabled, the CPU does quite a bit more
work, as expected (though it still seems that you don't
really need a very powerful CPU to make use of this):
And the write speed goes up almost to a gigabyte per second,
pretty neat if you ask me.
Side note: ZFS' lz4 compression is allegedly smart enough
not to try to compress incompressible data, such as media
files which are already compressed, which should prevent
such writes from being slowed down. Very nice IMHO.
That's it for today. What's still left to do at this point
is installing some sound-dampening materials (the rig is a
bit on the loud side, even despite being in its own room),
and possibly upgrading to more RAM, the rest will probably
stay like this for a while. If I really do upgrade to more
RAM, I'll adjust the VMs accordingly and run the tests
again, just to see if that really makes a difference. So far
I have been unable to get better performance from my ZFS
pools by allocating more RAM, or even running benches
directly on the host machine with the full 12 GB RAM and
eight cores/sixteen threads.
Cheers,
-aw
  #67
Old 27-04-14, 11:01 PM
d1974's Avatar
d1974 d1974 is offline
Member
Epic so far.
  #68
Old 27-04-14, 11:07 PM
OC3D Elite
Originally Posted by d1974 View Post
Epic so far.
Thanks! I must say I have rather enjoyed building this, something different
from the usual W/C stuff I have done in my other builds. Not that that is not
awesome, but the mind appreciates some change from time to time.
  #69
Old 10-05-14, 03:58 PM
OC3D Elite
Sound Dampening & Final Update
Sound Dampening, Final Pics
As mentioned previously, the 92 mm fans are rather noisy,
but I didn't want to replace them. For one thing, I do
actually need some powerful fans to move air from the HDD
compartment into the M/B compartment, on the other hand I
didn't feel like spending more money on expensive fans.
For this purpose, I ordered some AcoustiPack foam in various
thicknesses (12 mm, 7 mm and 4 mm) and lined parts of
the case with them. I wasn't quite sure how well they
would work, as my past experiences with acoustic dampening
materials weren't all that impressive, but to my surprise,
they're actually pretty damn effective.
I have also put in another 12 GB or RAM. I was lucky enough
to get six 2 GB sticks of the exact same RAM I already had
for 70 USD (plus shipping and fees, but still a pretty good
price IMHO) from eBay. 24 GB should easily suffice for my
purposes.
Lastly, I've repurposed the 2.5" drive cage from my Caselabs
SMH10; cleaner than the rather improvised mount from before.
For the time being, the build is now pretty much complete.
Cost Analysis
One of the original goals was to not have this become
ridiculously expensive. Uhm, yeah, you know how these things
usually go.
Total system cost: ~5,000 USD
of which were HDDs: ~2,500 USD
My share of the total cost is ~42%, the remainder was on my
dad, which is pretty fair I think. In the long run, my share
will probably rise as I'll most likely be the one paying for
most future storage expansions (at the moment I've paid for
~54% of the storage cost, and ~31% of the remaining
components).
One thing to keep in mind though is that some of these costs
go back a while as not all HDDs were bought for this server
but have been migrated into it from other machines. So the
actual project costs were less by about 1,300 USD.
Overall I'm still pretty happy with the price/performance
ratio. There aren't really that many areas where I could
have saved a lot of money without also taking noticeably
hits in performance or features.
I could have gone with a single-socket motherboard, or a
dual socket one with fewer features (say, fewer onboard
SAS/SATA ports as I'm not using nearly all of the ones this
one has due to the 2 TB disk limit), but most of the
features this one has I wouldn't want to miss TBH (the four
LAN ports are very handy, and IPMI is just freaking
awesome). And let's be honest: A dual-socket board just
looks freaking awesome (OK, I'll concede that that's not the
best argument, bit still, it does!).
Other than that, I could have gone with some cheaper CPU
coolers as the 40 W CPUs (btw., core voltage is ~0.9 V )
don't really require much in that area, but the rest is
pretty much what I [s]want[/s] need for an acceptable price.
Anyway, enough blabbering:
Final Pics
So, some final pics (I finally managed to acquire our DSLR
for these):
That Caselabs drive cage I mentioned. The top drive is the
WDC VelociRaptor.
And some more cable shots, because why not.
Looks much better with all RAM slots filled IMHO.
It's kinda funny: Considering how large the M/B compartment
actually is, it's pretty packed now with everything that's
in there. The impression is even stronger in person than on
the pics.
Thanks for tagging along everyone, and until next time!
  #70
Old 10-05-14, 05:24 PM
Cru's Avatar
Cru Cru is offline
OC3D Elite
brb changing pants
Tags
2cpu, san ace, server, supermicro
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
