Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
Thread Tools Display Modes
  #1
Old 24-02-21, 02:32 PM
WYP's Avatar
WYP WYP is offline
News Guru
M1-Powered Mac Users Report excessive SSD Wear - May Compromise Device Longevity
Some Mac users could see their M1-powered devices die within two years thanks to SSD wear.
Read more about M1 Mac users reporting excessive SSD wear.
__________________
_______________________________
Twitter - @WYP_PC
  #2
Old 24-02-21, 03:51 PM
hmmblah's Avatar
hmmblah hmmblah is offline
Moderator
It's a good thing Mac's are easy to service and parts like an SSD are very easy to swap out. /s
__________________
CaseLabs Mercury S3 | AMD 3900X | ROG CH8 Impact | RTX 2080 Super | 32GB DDR4 | 1TB NVMe
Acer Predator Z35P
  #3
Old 24-02-21, 04:40 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Yay so it's not just PC early adopters taking one up the jacksie !
__________________
If you don't like what I post don't read it.
  #4
Old 25-02-21, 11:15 AM
dazbobaby's Avatar
dazbobaby dazbobaby is offline
Newbie
I bought one in November, and it taken until 2 weeks ago for apple to fix OS bugs before I could even use it.
They screwed up the security, sound hardware, drivers, and midi. So I couldn't use with my DDJ 1000
Even though it's now patched and updated, I can only only ever use it with the internal SSD. Full disclosure, I could see problems like this down the road, so I bought an NVMe and a thunderbolt 3 enclosure and I run it from that. But because of the way that Apple have the security setup, you can't install kernel extensions (kexts) to external drives, only the internal.
So eventually one day the internal SSD will die. . . and I'll have a brick.
I will say this, it does fly like everyone says.
I will stick with it and use the external SSD for everything else, and reboot to the internal drive when I need to DJ. That should help with the longevity.
  #5
Old 25-02-21, 04:55 PM
demonking's Avatar
demonking demonking is offline
OC3D Elite
Not to worry, as long as it lasts longer than the warranty
You can always purchase AppleCare for an extended period if this worries you
or buy a brand new Mac when this happens, Apple has an extensive range to meet nobodies requirements at prices to make your house seem cheap
Thanks for choosing Apple
  #6
Old 25-02-21, 06:13 PM
looz's Avatar
looz looz is offline
OC3D Elite
If MacBooks are a poor deal, what laptop beats M1 Air's price to performance ratio? Without even factoring in the good quality monitor, speakers, keyboard and trackpad?
Obviously if the soldered SSDs start going pop early, it changes the value proposition, but it's a bit early to claim it to be a widespread problem, and is also likely to be patchable.
__________________
i7 9900k - 16GB - 3080 XC3 Ultra - 660p 1TB + MX500 2TB - HE-4XX w/ Topping D30+A30
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
