Go Back   OC3D Forums > [OC3D] Processors & Platforms > Overclocking
  #11
Old 26-02-18, 12:43 PM
Kaapstad's Avatar
Kaapstad Kaapstad is offline
OC3D Elite
Originally Posted by Arne Saknussemm View Post
Yes, was quite clear....i just don't have an extreme run yet
The Physics test on the extreme version is quite hard on overclocks and will knock over a dodgy one very quick.
The standard version of the Timespy Physics is not very good for testing CPUs with lots of cores as it does not use them all whereas the Extreme version does use all the cores.
__________________
OC3D Overclockers Club Member
#041
GTX 960 owner and proud of it.
  #12
Old 26-02-18, 02:35 PM
Arne Saknussemm's Avatar
Arne Saknussemm Arne Saknussemm is offline
Member
Here's a Time Spy Extreme for apples to apples
https://www.3dmark.com/3dm/25343602
Physics score is 5606 @4.2GHz
The hardest thing on a CPU OC I have found is VRay bench
Timespy is telling me I need a new GPU :-(
__________________
  #13
Old 26-02-18, 05:57 PM
Kaapstad's Avatar
OC3D Elite
That is a good score for Timespy Extreme, it is quite tough on GPUs as well.
__________________
#041
  #14
Old 04-03-18, 09:09 PM
woppy101 woppy101 is offline
Advanced Member
Originally Posted by tinytomlogan View Post
Hey dude, I know the CPU's are there. My initial sample was much better than the ones I have now. Sadly the 3.8 CPU's are what I would say are the normal ones.
Youve definitely won the silicone lottery with yours. Ive got two 1950X's that came from different sides of the planet and they both stop at 3.8 stable. I can screenshot high easy peasey I just cant put them under extended load
Tom would you consider 2 hours of AIDA64 to be some what stable? I have my 1920x @4ghz 1.416v idle 1.381v load and SOC @1.21v
__________________
All custom loop, 1920X ThreadRipper @ 4ghz
Asus X399 Zenith Extreme, GTX1080Ti
32gig GSkill Trident Z RGB 3200mhz @3600mhz,EVGA SuperNova 1200W Platinum
Tags
overclocking, ryzen, temps, threadripper
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
