Go Back   OC3D Forums > [OC3D] Cooling Forum > Cooling - Other
  #11
Old 18-03-17, 07:15 PM
Davva2004's Avatar
Davva2004 Davva2004 is offline
OC3D Elite
I use the X method, check this video out comparing the methods.
https://youtu.be/qc7bCC1TmVg
__________________
  #12
Old 19-03-17, 07:15 PM
Hobby Gamer Hobby Gamer is offline
Newbie
Cool video man. That liquid metal at the end is the coolest of the bunch. (I could become The Silver Surfer with that.)
  #13
Old 19-03-17, 08:26 PM
Bartacus Bartacus is offline
OC3D Elite
That liquid metal spreads surprisingly well with only a small amount. It's definitely a bit trickier to "paint" the IHS with the brush that comes with it, but it's awesome stuff.
__________________
Games: Ryzen 5950X on GB Aorus Master X570 / Asus TUF 6900XT / 64GB TridentZ Royal 3600CL16 (16GB x 4) / custom loop
Workstation: Threadripper 2950x on GB Aorus Xtreme X399 / Zotac 2080ti / 32GB TridentZ 3200CL14 (8GB x 4) / custom loop
Home Theatre: Ryzen 3900X on Asus C7H X470 / Radeon VII / 16GB G.Skill 3600CL15 (8GB x 2)
/ custom loop
  #14
Old 20-03-17, 11:28 AM
Newbie
I found Liquid Ultra, Liquid Pro (and others) from Coollaboratory, through the "old" reviews over at Benchmarkreviews. But I also read that liquid metal as a TIM can cause corrosion when applied to surfaces it was not designed for.
  #15
Old 20-03-17, 11:37 AM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
Aye you can't use it on Aluminium it's only suitable for Copper or Nickle plated coolers.
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #16
Old 20-03-17, 12:08 PM
Newbie
So it's true.
I also bumped into Liquid Copper TIM at Coollaboratory. In the description it said something like suitable for all surfaces. I'm definitely going to look up the performance in reviews with newer CPUs (if there are any newer reviews).
Tags
application method, ryzen, ryzen die, thermal compound, thermal paste
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
