  #1
Old 16-09-20, 05:35 PM
neSSa SS Mods neSSa SS Mods is offline
Member
ROGastic
Hello friends,
Guided by the need for the ultimate workstation machine, I throw myself into a project that consists of a complete change of the interior and a bit of the exterior of the CM Cosmos 25th edition case.
As you can see in the renders below, I plan to insert a large EKWB 540 radiator and provide airflow through the air tunnel with 4x120mm fans. This project also includes a complete EKWB LC system for which I will specially customize the custom distro/reservoire.
Hardware:
ASUS ROG Strix Z490 A-Gaming
Intel i9 10900
Adata XPG SPECTRIX D50 DDR4-3600Mhz RGB 4x8Gb
Adata XGP SPECTRIX S40G RGB M.2 1Tb
Cooler Master V1000 Platinum
Cooler Master MasterFan MF120 Halo White Edition
EKWB all water cooling parts and components
I know this case has been redesigned many times but I will do my best to make something different!
Thanks for following!
BR neSSa
  #2
Old 27-09-20, 07:30 AM
Member
Work on the inside aluminum parts:
  #3
Old 29-09-20, 08:29 AM
Member
Motherboard has arrived, beautiful white/silver ROG Strix z490, perfectly much with all my idea of this build
  #4
Old 01-10-20, 06:06 AM
Member
Cutting, grinding, sanding ...
  #5
Old 06-10-20, 02:57 PM
Member
Cooler Master V1000, must be white
  #6
Old 07-10-20, 11:32 AM
Member
Powder coating is done, same shade as EKWB fittings
  #7
Old 09-10-20, 07:26 AM
Member
Oh, these fittings and CPU block fit perfectly!
  #8
Old 09-10-20, 08:39 AM
trawetSluaP's Avatar
trawetSluaP trawetSluaP is offline
OC3D Crew
Nice! This is looking fantastic!
Those fittings are gorgeous.
I wanna replace my fittings with those as I have the previous gen EK ones but when added together it's expensive!
Can't wait to see thus build evolve.
__________________
Enthoo Elite | R7-5800X | X570 Tomahawk | Dominator Platinum 32GB | RTX 2080 FE | 960 Pro 512GB, 840 Evo 250GB x 2 | EVGA SuperNOVA 1200 P2 | ViewSonic XG270QG, MX27AQ | Custom Watercooling Loop + Aquaero 6 XT
  #9
Old 10-10-20, 12:43 PM
Member
Assembling...
  #10
Old 11-10-20, 06:34 PM
Member
Adata XPG Spectrix D50 4x8Gb 3600Mhz
End short video:
https://youtu.be/72f3DNkfg9I
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
