Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Closed Thread
  #1
Old 28-11-18, 04:26 PM
Dawelio's Avatar
Dawelio Dawelio is online now
OC3D Elite
Do you need to connect both 8pin and 4pin EPS on Asus Rog Maximum XI Formula?
Hey guys,
I’ve got a question regarding my ASUS ROG MAXIMUS XI FORMULA motherboard. Is it really necessary to have the 8 pin EPS CPU cable and the 4 pin? Or will it just be fine with the single 8 pin?... Why’s there another 4 pin for really?...
Thanks,
Dawelio
  #2
Old 28-11-18, 04:40 PM
SuB's Avatar
SuB SuB is offline
The Webmaster
title edited because of usual vague'ness
OnTopic.. Have you RTFM'd?
__________________
Gigabyte Z390 Aorus Pro | i7-8700k | 32GB Corsair Vengeance 3000Mhz DDR4 | nVidia RTX 2080Ti | Creative Audigy Rx | 1Tb Samsung 970 EVO+ M.2 | 1TB Samsung 860 QVO | 2TB Seagate Barracuda | Corsair RM850 | Fractal Define S | Noctua NH-U14S | Roccat Kone Optical - Navy Storm | QPad MK85 Pro w/ Cherry Red MX | DELL U2413 + 2 x U2412M | AKG K702's | AKG K7XX S/N#000016 | Beyerdynamic DT770 Pro 250Ohm | TM Hotas Warthog Stick and Throttle | Saitek Combat Pro Pedals | TrackIR 5 | TrackClip Pro
Notice: Don't feed the trolls!
  #3
Old 28-11-18, 05:47 PM
Dawelio's Avatar
OC3D Elite
Because of usual doucheness answer from you, the answer to your question is yes.
Of course I’ve read the f*king manual, as you plainly put it in your link, but couldn’t find a straight answer to my question. Hence me asking here... But seeing as everytime I try to ask something I can’t find an answer to on the internet, I always get an ”dummy stamp” response from you.
I ask here because this community consist of people way more experienced and knowledgeable than me. And I do have learned my lessons of doing the research I can, before asking on here.
So I’d advice you to please stop with all of the ”Was it hard to Google” it and if I’ve read the manual or not. Cause I’ve done both.
Now that that’s out of the way, anyone that could give me a clearer picture on this?...
Cause it works with the 8 pin, just not sure what the + 4 pin is really for and if it’s actually required as well or not?...
  #4
Old 28-11-18, 06:02 PM
Dark NighT's Avatar
Dark NighT Dark NighT is online now
OC3D Elite
You don't need to connect the 4pin for standard use or some overclocking, the only time you would need that is if you where to go deep subzero overclocking, way past -150c.
Just put in the 8 pin and that will suffice.
  #5
Old 28-11-18, 06:19 PM
trawetSluaP's Avatar
trawetSluaP trawetSluaP is offline
OC3D Crew
That's my understanding also but if you have a spare cable you might as well connect it - I always do.
__________________
5000D | R7-5800X | X570 Tomahawk | Dominator Platinum 32GB | RTX 2080 FE | 960 Pro 512GB | EVGA SuperNOVA 1200 P2 | ViewSonic XG270QG| Custom Watercooling Loop + Aquaero 6 XT
  #6
Old 28-11-18, 06:21 PM
AMD Enthusiast
To be fair the manual should have that answer. You probably didn't see it. As for the common sense part, every board has an 8 and it's fine. Which should make you guess an extra 4 isn't needed. Even if you didn't realize that you wouldn't hurt anything by trying to boot without it. The system wouldn't boot if it needed it and you'd get an error telling you as such.
  #7
Old 28-11-18, 06:27 PM
Dawelio's Avatar
OC3D Elite
Thanks everyone for your replies, much appreciated!
To answer you NBD, what I can find in the manual regarding the EPS connectors are the following:
• DO NOT connect the 4-pin power plug only, the motherboard may overheat under heavy usage.
• Ensure to connect the 8-pin power plug, or connect both the 8-pin and 4-pin power plugs.
And to my understanding, that doesn’t specifically answers my question really... Just says in general.
The reason I ask is I’m about to order custom cables and wondering if I should/need to add that extra 4 pin or not.
  #8
Old 28-11-18, 06:31 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Depends. On my FX Crosshair it was for the memory. 8 phase for the CPU and four for the RAM.
__________________
If you don't like what I post don't read it.
  #9
Old 28-11-18, 06:42 PM
Dark NighT's Avatar
OC3D Elite
The memory might have had a 4 phase, but no memory draws that amount of power, like ever to need a 4pin on its own.
Sounds like a wicked power design :P
  #10
Old 28-11-18, 06:45 PM
AlienALX's Avatar
OC3D Elite
I'm glad you have experience with my motherboard. Because I really didn't have a clue (yes that was terribly sarcastic)
http://m.hardocp.com/article/2012/11...board_review/1
The original board used an 8+2 power phase solution and the Formula-Z uses an 8+2+2 setup
Noting, the last two phases were for the memory and got their power from the 4 pin. Without which the board would not boot.
__________________
Closed Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
