Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
  #1
Old 26-08-15, 09:23 AM
WYP's Avatar
WYP WYP is offline
News Guru
AMD R9 Nano specification leaked - has 4096 GPU cores
Specifications for AMD's R9 "Fury" Nano have been leaked, confirming that the GPU has 4096 GCN cores and uses full AMD Fiji Silicon.
See the specification of AMD's R9 Nano.
__________________
_______________________________
Twitter - @WYP_PC
  #2
Old 26-08-15, 09:29 AM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
I've never understood this whole thing with TDP etc? ...
And no backplate, whaaat? ...
  #3
Old 26-08-15, 09:45 AM
SuB's Avatar
SuB SuB is offline
The Webmaster
All the ram is 'on-chip' so no backplate needed
__________________
Gigabyte Z390 Aorus Pro | i7-8700k | 32GB Corsair Vengeance 3000Mhz DDR4 | nVidia RTX 2080Ti | Creative Audigy Rx | 1Tb Samsung 970 EVO+ M.2 | 1TB Samsung 860 QVO | 2TB Seagate Barracuda | Corsair RM850 | Fractal Define S | Noctua NH-U14S | Roccat Kone Optical - Navy Storm | QPad MK85 Pro w/ Cherry Red MX | DELL U2413 + 2 x U2412M | AKG K702's | AKG K7XX S/N#000016 | Beyerdynamic DT770 Pro 250Ohm | TM Hotas Warthog Stick and Throttle | Saitek Combat Pro Pedals | TrackIR 5 | TrackClip Pro
Notice: Don't feed the trolls!
  #4
Old 26-08-15, 09:47 AM
WYP's Avatar
WYP WYP is offline
News Guru
TDP stands for Thermal Design Power, and it simply is how much heat a component produces or how much power it consumes.
AMD have lowered the TDP drastically by reducing clock speeds, moving the GPU to a much more efficient lower clocked state.
Typically when you increase clock speeds you get diminishing returns when it comes to power consumption, hence why more efficient models of CPUs and GPUs tend to be running at lower clocks.
From what I can see from leaked information AMD R9 Nano's clock speed fluctuates to maintain a low TDP, with a max clock speed of 1000MHz.
This is a simple guess, but with this being at a similar size to Nvidia's competing GTX 970 for MATX powerhouse I imagine that AMD wins by a margin of 20-30% or so, which is awesome for AMD.
__________________
Twitter - @WYP_PC
  #5
Old 26-08-15, 09:56 AM
Dawelio's Avatar
OC3D Elite
Cool, thanks for that nice explanation bud
So this, the AMD R9 Nano, will be the "direct" competitior to Nvidia's GTX 970?...
  #6
Old 26-08-15, 10:02 AM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Closer to the 980 in reality judging from various bits of info floating around.
__________________
= Steam/Origin/Uplay - Dicehunter =
  #7
Old 26-08-15, 10:04 AM
SpencerUk SpencerUk is offline
Member
The tipping point here needs to be the price..
__________________
Laptop (Portable Driver): Macbook Pro 15 (Mid 2012)
Current Desktop: The Darkest Knight
Desktop 1: (Antec 300, Old Q6600) >> Retired
Desktop 2: (Antec Aria, Retired Opteron 185) >> Zen Upgrade (Eventually)
Server: (Bit-Fenix Phenom Mini ITX, i5 4570S, 8GB Ram, 18TB HDD Raid 1)
  #8
Old 26-08-15, 10:06 AM
Dawelio's Avatar
OC3D Elite
Ohhh nice one, tasty ... Does anyone perhaps know if this will be like the Titan of Nvidia or will it come with custom PCBs and custom coolers?. Would be nice to have this with a semi passive cooler
I agree
  #9
Old 26-08-15, 10:17 AM
WYP's Avatar
WYP WYP is offline
News Guru
it will have performance which is higher than the R9 390X and similar to the GTX 980, at least is recent estimates are accurate.
I compared it to the GTX 970 as it is the most powerful Nvidia GPU of that form factor.
__________________
Twitter - @WYP_PC
  #10
Old 26-08-15, 10:24 AM
Kushiro Kushiro is offline
OC3D Elite
Benches!!!
__________________
i7 5930k 4.7Ghz ~1.34v - Asus X99 Deluxe - G.Skill 32GB 2800mhz 4x8GB - NZXT Switch 810 White Edition - 3x EVGA Geforce GTX 980Ti - 2x Samsung 850 2TB - Corsair AX1500i
Watercooling - custom
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
