Go Back   OC3D Forums > [OC3D] Off Topic > Off Topic Chat
  #10591
Old 13-02-20, 10:49 AM
Damien c Damien c is offline
OC3D Elite
Yeah going to take a while to fully sort out, but once it's done it should look a lot better.
__________________
Gaming PC: AMD 5950X, 32GB Corsiar DDR4, MSI 2080Ti, Samsung 980 Pro 1TB NVME
Server PC: 2700x, 16GB Corsair DDR4, MSI GTX 1660Ti, Gigabyte 120Gb M.2, Crucial 240Gb SSD, WD Blue 500Gb SSD, 2x Seagate 6Tb HDD's
  #10592
Old 13-02-20, 10:11 PM
Kei's Avatar
Kei Kei is offline
OC3D Crew
4 Transformers and 2 chokes. 2 Sowter UA21 push-pull output transformers, 2, Primary windings 410-0-410V/3.15-0-3.15V/5-0V mains transformers and 2 VVT 10H 180mA chokes.
I've been planning to build a pair of custom monoblock valve power amplifiers in the spring. I've been trying to get around to building my own power amps for the last 8 years. Using a really old Mullard push pull design from the mid 50's called a 5-20. (5 valves, 20 watts) That might not sound that powerful today but having measured how much peak power I actually use from my current solid state power amp, it's plenty. (around 5 watts for loud)
Currently it's still in the design phase and is looking like this.
and a basic 3d render of the chassis design.
Once all the bits arrive, I may start a project thread on it. I've got a few weeks wait as the transformers are made to order.
__________________
Gigabyte Aorus X399 Gaming 7 ⁞⁞ Ryzen TR 1920x ⁞⁞ 32GB Team 3200C14 ⁞⁞ EK Blocks + αcool XT45 rads ⁞⁞ AMD Radeon Vega 56 ⁞⁞ GTX 780 3GB
Enthoo Primo ⁞⁞ Seasonic Prime 750W ⁞⁞ Polaris SM961 256GB ⁞⁞ WD SN750 1TB ⁞⁞ 850 Pro 512GB ⁞⁞ M500 240GB ⁞⁞ WD 6TB, 4TB & 1TB
Samsung C27HG70 ⁞⁞ Ducky Shine 5 ⁞⁞ Intel X710 NIC ⁞⁞ AJA Kona LSe ⁞⁞ RME HDSPe AIO ⁞⁞ Marantz AV7701 ⁞⁞ Tannoy SRM 10B
  #10593
Old 13-02-20, 10:52 PM
Bartacus Bartacus is offline
OC3D Elite
Good move on that UPS Dice! People fail to realize how valuable those things are, especially in places with flaky old wiring.
Got some new toys recently myself:
Optimus signature water block for AM4, with black mounting plate, nickel plating. Feels like serious hardware:
Micro fins are micro:
The thermal paste in the first pic is Kingpin KPx (never tried it before, heard great things). RAM is G.Skill TridentZ Neo 16GB x 2, the good 3600 CL16/16/16/36 stuff.
__________________
Games: Ryzen 5950X on GB Aorus Master X570 / Asus TUF 6900XT / 32GB TridentZ Neo 3600CL16 (16GB x 2) / custom loop
Workstation: Threadripper 2950x on GB Aorus Xtreme X399 / Zotac 2080ti / 32GB TridentZ 3200CL14 (8GB x 4) / custom loop
Home Theatre: Ryzen 3900X on Asus C7H X470 / Radeon VII / 16GB G.Skill 3600CL15 (8GB x 2)
/ custom loop
  #10594
Old 17-02-20, 08:54 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Bought this a couple of weeks ago, but just got to it Friday.
Yeah, I know I bought a Bose one last month... That is going to be my center channel speaker, this is going to be the rears. I have a 5.1 pre amp that I am making mostly wireless so I don't have to run cables. You connect the output of the amp to this.
Then at the other end connect the receiver to the sound bar, hey presto rear speaker surround. I'm doing it like this because sound bars are cheap (that one especially so, £49) and that one requires no extra mounting hardware you just slot it onto screws on the wall.
__________________
If you don't like what I post don't read it.
  #10595
Old 18-02-20, 08:39 PM
Kei's Avatar
Kei Kei is offline
OC3D Crew
The input and phase splitter valves for my power amp project. New old stock General electric valves were chosen as they were actually quite cheap considering what "NOS" valves tend to go for and they have a good reputation for quality.
2x 6267/EF86 west german made
2x 5751 JAN (joint army navy military valves) made in the USA
EDIT: Output valves and the rectifier valves arrived today.
4x matched Tung-Sol EL34B output valves
2x Sovtek 5AR4 rectifiers
__________________
  #10596
Old 20-02-20, 07:13 PM
AlienALX's Avatar
OC3D Elite
Shot in the dark @ £85. Seller says it does not boot, just white text on black background. I'm thinking dead HDD.
Edit. Turns out I did quite well.
I5 3330 (could have been much worse, Sandy I3)
GT 610 (barf, that's going)
6GB RAM (easy to upgrade to 8)
240w PSU (could have been a 180)
And etc. So yeah, not bad. Will make a cracking media PC
__________________
  #10597
Old 21-02-20, 10:04 PM
Kei's Avatar
Kei Kei is offline
OC3D Crew
4x Belton noval sockets
Assorted 22AWG hookup wire
2x 3mm turret boards
100x 3mm turrets
8x 30mm capacitor clamps
__________________
  #10598
Old 23-02-20, 10:34 AM
Zoot's Avatar
Zoot Zoot is offline
OC3D Elite
New Toy!
For anyone wondering, it's an X470 motherboard with IPMI - which allows me to access the BIOS remotely over the network. All server boards worth their salt have this feature.
It basically means I can shove the server into a press and never have to plug a monitor, mouse or keyboard into it ever again even if there's a hardware problem. An example - you can even flash the BIOS remotely if you stick an unsupported CPU into it.
No way I would ever go back to using a desktop motherboard for my Home Server now.
Click image for larger version
__________________
Desktop: AMD Ryzen 7 3700X | X570i Aorus | 32GB Corsair DDR4-3200MHz | RX 5700 XT | Samsung 980 Pro 1TB | Fractal Define Nano S
Server: AMD Ryzen 5 2600| ASRock Rack X470D4U | 32GB DDR4-2666MHz | LSI SAS9207-8i | 68TB | Fractal Define R5 | Debian 10
  #10599
Old 23-02-20, 07:07 PM
OC3D Elite
One word: BIG!
Ender 5 Plus 3d printer. It's a bit huge!
__________________
/ custom loop
  #10600
Old 23-02-20, 08:32 PM
WYP's Avatar
WYP WYP is offline
News Guru
Originally Posted by Bartacus View Post
One word: BIG!
Ooooo. What's the build area on that? That's HUGE!
__________________
_______________________________
Twitter - @WYP_PC
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
