Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #11
Old 09-01-18, 11:22 AM
Warchild Warchild is online now
OC3D Elite
Originally Posted by Dicehunter View Post
Was just curious seeing as the window has a slight tint to it which may get damaged with standard window cleaner unless the tint is actually throughout the glass, Would be nice if a Corsair rep could chime in
Wouldn't have this problem if you bought that Dyson Hot and Cold Purifier I posted ages ago. I know you were tempted!!!
you can always try fluorinated silane on it. That would make it both water repellant and dust proof. But don't think its a long term solution.
  #12
Old 09-01-18, 01:32 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Originally Posted by Corsair Nick View Post
Any glass cleaner should work fine. Automotive windows are tempered as well, so anything you use to clean a window on your car will work.
Cooleo thank you
Originally Posted by mutantaxe View Post
like they said..small amount of vinegar, small amount of concentrated washing up detergent and lots of water in a spray bottle and and window or mirror will be so clean . Careful on doors or you will walk through them.....................
btw: and you car windows will be brilliant
I shall give this a go
For £500 it's going to have to wait a while
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - GTX 1080 Ti FE @ 2000/6000 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
  #13
Old 09-01-18, 06:01 PM
AlienALX's Avatar
AlienALX AlienALX is online now
OC3D Elite
Rain X?
__________________
"Those really high 20 series prices are just place holders"
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
