Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #11
Old 30-06-16, 08:41 AM
suimui suimui is offline
Newbie
i've tried and tried but i dont get to fit the h100i v2 into a Corsair 350D without loosing the rear fan, the HDD Cage or the DvD Slots.
whats wrong with this oO
  #12
Old 11-07-16, 05:44 PM
Grey_beard's Avatar
Grey_beard Grey_beard is offline
OC3D Elite
Tubes hitting the rear fan? If it's really that tight fit, you may have to get a slim 120mm fan to put on the rear.
  #13
Old 09-01-18, 02:54 AM
mutantaxe mutantaxe is offline
Member
needs updating with the new 150i
will that fit into a 780T case neatly at the top...have a 115i and only have 60mm from end of rad to the next available hole?
at the front have 3 120mm RGB HD120's that I want to leave there so basically want at the top
  #14
Old 16-01-18, 09:52 PM
Corsair Nick Corsair Nick is offline
Corsair Rep
Should fit without issues in the 780T. That cases has a lot of room in the top. Either the radiator or fans will be in the top area below the dust filter, and the other will be on the inside cabin.
  #15
Old 15-06-18, 06:05 PM
SkjalgT SkjalgT is offline
Newbie
Originally Posted by Grey_beard View Post
A respectable rule
In deed. The manufacturers skimp on the fans all the time. Not so much a cooling issue, more of a noise problem IMHO..
  #16
Old 16-06-18, 01:40 AM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
