Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
Thread Tools Display Modes
  #11
Old 20-03-14, 04:06 PM
SieB's Avatar
SieB SieB is offline
OC3D Elite
Originally Posted by Watsyerproblem View Post
clock increases are rumored, could potentially be higher (doubt it though)
The better TIM etc will allow us to push volts a bit more while still being able to cool the bloody things, which should make higher overclocks more achievable on the average chip (if you push the volts).
It also makes a water cooling loop a more attractive option, considering since Ivy you couldn't push the volts high enough to need it (before you hit the CPUs volt limit due to the TIM).
I know that dude but it's not going to make much difference to the average user, it's only going to benefit people who are pushing high overclocks for benching.
100mhz wont make much of a difference, you can get that just by overclocking.
It seems like Intel are just releasing another load of CPUs with no real improvements other than efficiency. The last time we had CPUs that were a game changer was Sandybridge. It would be good to see Intel give us something worth upgrading for rather than side grading for better efficiency.
Add on top that you need to buy a Z97 motherboard for these CPUs as well, then unless there is anything other than better TIM and a 100mhz clock increase, it's not really worth it unless you are building a new rig.
__________________
NZXT Switch 810 - i7 6700K - MSI Z170A Krait - 32GB Corsair Platinum SE - MSI 1070 - Crucial MX100 256GB SSD - Samsung F3 1TB HDD - Corsair H100 - Corsair RM1000i SE - Asus VE247H
PC Audio: Asus Xonar STX - Sennheiser HD650.
Portable Audio: FiiO X3II - Audiofly AF140 - Etymotic ER4s - Fidue A83.
  #12
Old 20-03-14, 04:13 PM
WYP's Avatar
WYP WYP is offline
News Guru
Agreed, same can be said for all refreshed like this, trinity to richland being another recent example of the same thing (clock wise, not TIM of course).
Potentially motherboard manufacturers could get them to support current z87 motherboards with a simple bios update, but that depends if intel has done something to negate that or not. The 9-series and 8 series have got the same cpu pin interface.
__________________
_______________________________
Twitter - @WYP_PC
  #13
Old 20-03-14, 04:16 PM
SeekaX SeekaX is offline
OC3D Elite
well, we already knew that nothing game changing will happen until skylake for the average PC user. broadwell is just a refresh and this will be a special chip for overclockers, not an entire new family.
  #14
Old 20-03-14, 06:01 PM
Antony1995 Antony1995 is offline
Member
This may seem a bit of a noob question but I've never really understood chipsets completely, But I'm assuming the new Z97 Chipset will be compatible with the current range of Haswell CPU's am I right?
__________________
  #15
Old 20-03-14, 06:49 PM
OC3D Elite
not guaranteed. the chipset is not made for haswell CPUs, but because broadwell and haswell are so similar it will most likely still work.
  #16
Old 22-03-14, 07:10 PM
Member
I see, I'll hold out and see what happens before buying anything then.
__________________
  #17
Old 23-03-14, 03:47 AM
Bartacus Bartacus is offline
OC3D Elite
I see no compelling reason to upgrade my socket 2011 system. Heck, I could have kept my i7 920 running at 4Ghz + and still been happy. But I do like how Intel is apparently listening to complaints. No sane person WANTS to delid CPUs.
__________________
Guts: Ryzen 3900X / GB Aorus Master / 16GB TridentZ 3600CL15 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: Corsair Force MP600 1TB NVME / 6TB RAID0 HDD array / 4TB RAID0 SSD array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads + 240 rad / Heatkiller reservoir / dual D5 pumps
Tags
devil's canyon, haswell, intel, overclocking, tim
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
