Thread Tools Display Modes
  #11
Old 28-02-14, 05:23 PM
AMD Enthusiast
Original Equipment Manufacture. It just means this..
OEM versions of Windows 7 are identical to Full License Retail versions except for the following:
- OEM versions do not offer any free Microsoft direct support from Microsoft support personnel
- OEM licenses are tied to the very first computer you install and activate it on
- OEM versions allow all hardware upgrades except for an upgrade to a different model motherboard
- OEM versions cannot be used to directly upgrade from an older Windows operating system
Changing the CPU does not affect activation.
The reactivation threshold is about 3(iirc).
Replacing the hard disk does not affect Windows Activation.
Regarding the bold.. you could switch the hard drive and re install on a new drive and it would have no way of knowing which motherboard you were previously using.. so it should be okay.
  #12
Old 28-02-14, 05:28 PM
BuddhaCube's Avatar
BuddhaCube BuddhaCube is offline
Newbie
Uh oh.. I hope so. How will they know if I'm using it on a new Motherboard..
  #13
Old 28-02-14, 05:32 PM
AMD Enthusiast
Its tied into the OS and drive so when you boot it goes through sort of a checklist to make sure everything is okay(simplest explanation i can think of) and it the motherboard model changed it would not boot and probably give you an error.
  #14
Old 28-02-14, 05:42 PM
BuddhaCube's Avatar
Newbie
So I should probably erase OS of of SSD on the current MOBO, then build the new PC and try to re-install windows again then?
Tags
high-end, intel, mobo, ssd
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
