Go Back   OC3D Forums > [OC3D] Processors & Platforms > Platforms - Other
Thread Tools Display Modes
  #11
Old 15-12-13, 08:17 PM
yassarikhan786's Avatar
yassarikhan786 yassarikhan786 is offline
OC3D Elite
Another on the K95. I use one myself and I cannot recommend it more. The build quality is fantastic and it is a joy to use. As it's using Cherry MX Red switches, the keys may be too sensitive, so it may be a good idea to see if it's possible to try how the keys feel before you buy.
__________________
Motherboard: Asus P8P67 Pro (B3) || CPU: i7 2600k || Graphics Card: EVGA GTX 780 Ti ACX || Memory: 16GB - Mushkin Blackline 8GB + Corsair Vengeance LP 8GB || SSD's + HDD's: Samsung 850 EVO 500GB (OS + Programs) + Caviar Black 2TB (Games + Storage) || CPU Cooling: Noctua NH-D14 || Power Supply: BeQuiet Dark Power Pro P9 750W || Case: Corsair Obsidian 650D || Monitor(s): Dell U2410 + HP w1907v
  #12
Old 15-12-13, 08:38 PM
iBeInspire iBeInspire is offline
OC3D Elite
Steelseries are always my go-to for mice, Mionix are decent too
Pinky rest is a must for me though, that's why I like those two
__________________
/|i5 4690k @4.6Ghz @1.315v /|\ Asus Z97-AR /|\ 8Gb G.Skill RipjawsX /|\ Asus GTX970 Strix |\
/|TX550m /|\ Samsung 840 Pro |\
/|Asus Essence STU /|\ Hifiman HE-400S /|\ AKG K551|\
[OFFICIAL] OC3D Overclockers Club Member [#025]
  #13
Old 15-12-13, 09:11 PM
MrKambo's Avatar
MrKambo MrKambo is offline
OC3D Elite
Send a message via Skype™ to MrKambo
K70 and M65 from corsair are what i use, i used to have a roccat kove and arvo before, Corsair kit is 10000% better
__________________
steam|origin|insta:mrkambo
  #14
B3rni3 B3rni3 is offline
OC3D Crew
Im using the roccat kone xtd atm and it is a very good mouse. It is perfect for those who use a palm grip. It has a nice size and feel to it and adjustable weights in the base help make it a very precise mouse. I have noticed my aim and kdr went up when I switched from my razor imperator which always felt too light small and cheap. It also was a little inaccurate at times which drove me mad.
I would recommend the kone xtd even if it is a little expensive.
__________________
Case: Cosmos 2 Cpu: 3930k @ 4.6 ghz Mobo: Sabertooth CoolerH100 with Sp120 Quiet ed Ram: 16GB Vengence Gpu: Gtx 680 Sli w/ EVGA Backplates Psu: Ax760 Hdd: 2TB seagate green Ssd: 120GB Corsair Force GT + 240GB Sandisk Extreme
Nr. #002
  #15
Old 16-12-13, 07:49 AM
Zoot's Avatar
Zoot Zoot is offline
OC3D Elite
I've a Logitech g500s mouse and the G710+ mechanical keyboard.
I quite like the adjustable DPI, configurable profiles on the mouse and the feel of the MX browns on the keyboard, but then again I haven't used any other switches so I'm not the best source.
__________________
Desktop: AMD Ryzen 7 3700X | X570i Aorus | 32GB Corsair DDR4-3200MHz | RX 5700 XT | Aorus PCIe 4.0 1TB M.2 | Fractal Define Nano S
Home Server: AMD Ryzen 3 2200G | Asus Prime B450M-A | 16GB Crucial DDR4-2400MHz | 39TB | Fractal Design Define R5
HTPC: AMD Athlon 5350 | ASRock AM1H-ITX | 4GB Corsair DDR3-1333MHz | MiniBox M350
  #16
Old 16-12-13, 08:07 AM
QuietOne's Avatar
QuietOne QuietOne is offline
always shouting
I will have a look at all the peripherals that you guys use. So many choices
__________________
Wonderful signature by Wraithguard!
Member #045 of the official OC3D OC Club.
  #17
Old 17-12-13, 03:15 PM
Chadwokie Chadwokie is offline
Member
hey man just thought id add my 5 penny's worth
1st rocat kone my fav mouse iv ever had very comfy nice grip fits my hand only draw back is if your playing mmo's not many buttons
2nd iv had a razer lycosa keybord for near enough 5 years i think, i love the lower profile keys. (considering upgrading now to a mechanical keybord with low profile keys)
3rd before my kone i had a razer naga very good mouse tho the 1st version the keypad on the side wasnt very initiative if you can get the most of side keys go for one for mmos' other wise id stick with my kone for fps
  #18
Old 18-12-13, 06:02 PM
QuietOne's Avatar
always shouting
I have decided to go for this mouse
http://www.scan.co.uk/products/corsa...tons-black-usb
And this keyboard
http://www.scan.co.uk/products/corsa...ogrammable-usb
I would love to test them beforehand but nowhere around here as them so I will take a chance.
__________________
  #19
Old 18-12-13, 06:03 PM
OC3D Elite
And this keyboard
I'm sure you'll be very happy with the K95
__________________
  #20
Old 18-12-13, 06:12 PM
Jordan Jordan is offline
Advanced Member
You won't go wrong with those fella
Tags
gaming, keyboard, mouse
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
