Go Back   OC3D Forums > [OC3D] Hardware & Software > Software Section
Thread Tools Display Modes
  #11
Old 03-12-13, 10:35 AM
Mkilbride Mkilbride is offline
Member
I tried in safe mode. It froze there to. As for the zip files ,they're actually...the .255 type, so not zip or 7zip, I tried those command lines already man. It only detects about 10 at a time, and I have to keep typing
*100.zip
*101.zip
*102.zip
Ectera. It won't delete them all at once. However, something semes to be happening now in relations to this and I am leaving it on while I go to sleep soon and hoping it honestly deletes them, but yeah, I feel ed.
Hey...hey!
It just ended...and like...the FILES are gone, I think - but sometimes they appear gone, then re-appear! I dunno.... Windows is still running very slowly, but I can't see the files anymore.
Any recommended linux ones?
  #12
Old 03-12-13, 10:37 AM
maniac's Avatar
maniac maniac is offline
OC3D Elite
#legend
__________________
NZXT Switch 810 - Intel Core i7 950 - EVGA GTX580 SLI - Asus P6T - G.Skill Pi Series 6GB
Corsair H110 - Corsair HX850 - Intel 520 120GB - Acer V243H - Logitech G510 - Corsair M65
  #13
Old 03-12-13, 10:42 AM
Member
So, yes, this is a rather bad thing.
I think I just discovered a new way to troll somebody hardcore. Imagine if you took a 10? 20GB file, even, and did 1kb splits? Turned off the monitor and walked away. That person..
  #14
Old 03-12-13, 10:45 AM
Jeff_s510 Jeff_s510 is offline
Advanced Member
LOL i did this on accident a while ago on the school computer when trying to share a file with some of the class....set it to bites instead of MB. took a while to correct the issue
__________________
[email protected], CM Hyper 212+, 16GB Kingston HyperX 1600, Gigabyte Z68X UD3, Gigabyte 760 windforce OC, Corsair AX760i, Corsair 550D, 256GB OCZ Revodrive 3, 1.5 TB WD Black, 27" LG IPS, B&W 601 S3, Yamaha RX-V420
  #15
SPS SPS is offline
Moderator
.255 type, that's the extension?
Why not try *.255?
__________________
  #16
Old 03-12-13, 11:01 AM
Member
Ok SPS, but the thing is
All the files are .01, 0.2, ect, up into the hundreds of thousands.
  #17
Old 03-12-13, 11:03 AM
Snortan Snortan is offline
OC3D Elite
I don't think they have an extension, there is one main zip and the rest are 1xx... i think.
If you don't have any file on desktop that you need to keep then do
del /f /s /a "C:\users\yourusername\desktop\*"
which will delete everything on the desktop. Remember to empty the recycle bin btw.
For linux try Ubuntu or Linux Mint.
__________________
  #18
Old 03-12-13, 11:25 AM
looz's Avatar
looz looz is offline
OC3D Elite
Or just delete the whole desktop folder in explorer.
__________________
i7 8700k - 16GB - 2060 FE - 512GB 970 & 850 EVO - AKG K702
  #19
Old 03-12-13, 12:37 PM
SeekaX SeekaX is offline
OC3D Elite
iirc people used to do that with .bat scripts back like 15 years ago, but with thousands of subfolders so you couldn't delete them anymore because the OS couldn't handle the path.
  #20
Old 03-12-13, 01:11 PM
S_I_N's Avatar
S_I_N S_I_N is offline
OC3D Elite
I'd just format and be done sounds like its beyond fixing with the op's state of mind.
__________________
Intel 7700K
Aorus Z270 Gaming K7
2x8GB GSKILL Trident Z 3200MHz
Intel SSD6 256Gb x2 in Raid 0
Samsung 850 EVO 1TB
EVGA GTX1080 FTW2 iCX Heat Killer IV block
Custom water Cooled Hardware Labs GTS360/240
ThermalTake Grand RGB 1000w PSU
Corsair Crystal 570X
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
