Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #11
Old 06-01-14, 04:35 PM
Grey_beard's Avatar
Grey_beard Grey_beard is offline
OC3D Elite
Sorry I missed your question Punkisdead.. but yes, the 2 pin to 3pin is the cable that you need to use to connect your 600T fan controller to the Link Commander. The fan controller needs to be powered, so the molex needs to be connected as well. What fans do you have connected to the 600T fan controller? Make sure that you are using the latest Corsair Link SW, should be 2.5.5154
  #12
Old 23-05-14, 02:17 PM
PunkisDead's Avatar
PunkisDead PunkisDead is offline
Newbie
Edit; Will try to RMA article
__________________
Corsair Graphite 600T Black Intel [email protected]
EVGA GTX 780ti SLI Corsair Link Commander Mini
Asus Maximus VI Formula
Triple Qnix Evolution II
Dominator Platinum 32GB 1600GHz Corsair AX1200i
Corsair H100i 2x Corsair Neutron GTX 240 GB Raid0
  #13
Old 12-07-15, 05:21 PM
sprento sprento is offline
Advanced Member
Originally Posted by JR23 View Post
Also you didn't mention that the light on the commander flashes green-red-green-orange-green... Like a mad man, and apparently that means everything is working properly.
Lol, this started happening to mine last week, it was always white then all of a sudden it decided to break in to Benetton mode (thooper)
A bit of searching online and I figured out how to stop it and also how to manually change the colour but even with a saved profile, it's never the same colour after a computer restart. Since given up.
__________________
"It ain't about how hard you hit; it's about how hard you can get hit and keep moving forward. That's how winning is done." – Rocky Balboa
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
