Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #11
Old 22-07-13, 09:31 PM
Grey_beard's Avatar
Grey_beard Grey_beard is offline
OC3D Elite
Yes, that is correct. The pump/cooler will serve the same function like the PSU dongle, the one that is marked "Corsair Link Digital".
  #12
Old 22-07-13, 10:12 PM
remember300 remember300 is offline
OC3D Elite
I had it all easy with the commander node, btw grey beard im not sure were to ask this but its part of the i stuffs, the led's for the lighting kits were can i get more with out buying more nodes. as i dont need more nodes the kit its self says it can light at least several more
__________________
  #13
Old 22-07-13, 10:39 PM
Grey_beard's Avatar
OC3D Elite
This is still being discussed if are going to sell just LED strip with out the lighting node.. so I really don't know if this is going to happen or not at this point, but once I get an answer, I'll let you guys know.
  #14
Old 22-07-13, 10:52 PM
OC3D Elite
awesome lol i want to put the leds behind my monitor so when the case LED's change colour the ambient light does behind the monitor, cos im sad lol.
__________________
  #15
Old 22-07-13, 11:10 PM
Grey_beard's Avatar
OC3D Elite
That's a great idea, it'll give your room some sort of mood change every time LED color changes. I'll probably take it to the next level and run them around underneath my desk... it'd probably give the illusion that your desk is part of your PC hehe
  #16
Old 24-07-13, 09:41 PM
Mark3Max Mark3Max is offline
OC3D Crew
Hi Grey beard,
I have the h100i connected as you said , the cable from the psu to the block and the usb cable from the block to a usb port on the mb. I deleted my corsair link profile and uninstalled corsair link , also deleted temp files. Rebooted then installed the new corsair link version 2.4.4948. It's all working fine , h100i shows in CL , I can control the psu fan , but still doesn't show the psu temp.
I double checked all connections just to make sure.
Any idea why the psu temp won't show?
__________________
Corsair 650D, MSI Z77A-GD65 , I7-3770k, Corsair H100i w/sp120 QE ,G.Skill Ares 16gb 2133 c9, Asus Blu-Ray Burner, Asus Xonar STX ,Corsair Neutron GTX 240gb ,W.D. black 1TB ,Seagate 3TB, MSI GTX 680 Lightning, Corsair AX760i ,Case Fans : Front : CM 200 blue,Rear : Corsair AF 120 PE , Klipsch 2.1 , Sennheiser HD650 , 2 x Samsung 23" 1080p , Logitech G710+
  #17
Old 24-07-13, 11:21 PM
Grey_beard's Avatar
OC3D Elite
What about under Options tab > Devices in CL, do you see the PSU there at all? It's just odd to see the PSU fan detected but not the temp. Typically, if the fan is not detected, chances are the temp will also not be detected.
Try to stop CL then unplug the link cable connected on the pump and then plug it back in while the system is running.
  #18
Old 25-07-13, 12:06 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
I just downloaded and installed the latest Corsair link software from this thread as I realised that I hadn't installed it since my format and I noticed that the led's wont show the yellow color or my prefered white it's now a pink color not white oh yes it's a 100i yet before i put the software on the led's were white
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=32gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=MSI MPG341CQR=MSI GK80 Vigor=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #19
Old 25-07-13, 01:50 AM
OC3D Crew
The psu is listed , unplug the psu cable or the usb cable?
__________________
  #20
Old 25-07-13, 03:42 PM
Grey_beard's Avatar
OC3D Elite
The PSU cable connected to the pump, unplug it and plug it back in and see if that will trigger the sensor.
Excalibur - Try restarting your system or try playing around with the LED sliders and see if you can get the color your prefer.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
