Go Back   OC3D Forums > [OC3D] Hardware & Software > Software Section
Thread Tools Display Modes
  #11
Old 12-11-12, 08:35 AM
Josh Weston Josh Weston is offline
OC3D Elite
The home button refreshes your page?
  #12
Old 13-11-12, 12:34 PM
Svarog's Avatar
Svarog Svarog is offline
Newbie
Well well, it just happend in Firefox aswell.
__________________
Intel Core i7 4770K | Gigabyte Z87X-UD5H | 8GB G.Skill ARES C9 2133 MHz | Zotac GTX 680 4GB | Creative SoundBlaster ZxR | Crucial M4 256GB | OCZ Vertex 120GB | Western Digital 1TB 2,5" | SeaSonic Platinum 760
  #13
Old 14-11-12, 01:35 PM
boubou007 boubou007 is offline
Newbie
I'm having the same issue. I found this solution through google:
http://darktips.com/fix-flash-player...-screen-video/
It seems to be with Flash Player. Right-click on the video > Settings > Uncheck Enable Hardware acceleration
  #14
Old 14-11-12, 02:39 PM
Svarog's Avatar
Newbie
If you read my first post you could see i had alrdy tried that and does nothing to fix the problem.
I tried Flash Player 11.2 today as the issue started happening since then. But it still happens.
The only option i got left is reinstall Windows, which isn't gonna happen untill i upgrade my PC to Haswell.
__________________
  #15
Old 19-11-12, 06:52 PM
Svarog's Avatar
Newbie
So far Google Chrome works fine.
I bet that's because it has Flash built in?
__________________
  #16
Old 08-12-12, 10:31 AM
Svarog's Avatar
Newbie
Chrome also had the issue.
I decided to reinstall Windows yesterday and today it happend again. Must be something with my videocard then.
Never got any issues with games tho.
__________________
  #17
Old 14-12-12, 06:27 PM
Svarog's Avatar
Newbie
Found the issue, but i still gotta try it out.
It's a combination of NOD32 and 2 Windows Updates that cause data corruption during the download when a 3rd party driver working at Windows Filtering Platform layer intervenes in the communication.
http://forums.adobe.com/message/4777514
http://www.wilderssecurity.com/showthread.php?t=332920
I kinda started to lean towards Windows Updates last week.
Update:
Looks like uninstalling those 2 updates fixed the issue for now. Gotta wait for MS to fix the problem.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
