Thread Tools Display Modes
  #21
Old 08-08-12, 08:32 PM
dalewakelin's Avatar
dalewakelin dalewakelin is offline
OC3D Elite
Send a message via Skype™ to dalewakelin
Ok, i accept i am wrong. On an unrelated note, Is the Accelero Hybrid 7970 by Arctic cooling any good as in would it be worth buying?
__________________
  #22
Old 08-08-12, 08:35 PM
PapaSmurf6768's Avatar
PapaSmurf6768 PapaSmurf6768 is offline
OC3D Crew
Probably not worth buying, either water your your card properly or get one with a good air cooler.
  #23
Old 08-08-12, 08:36 PM
OC3D Elite
Ok, ty
Originally Posted by PetrolHead247 View Post
Depends what case he has. If he has a crap one with limited airflow and space inside he'll want a new one, if it's good then yeah no need for a new case. If so i'd actually get a GTX 570, it's cheaper and faster than a 7850 but just consumes a bit more power
My case is a modded rosewill ranger
__________________
  #24
Old 08-08-12, 11:57 PM
Josh Weston Josh Weston is offline
OC3D Elite
What's all this about a 8150 having 16 threads? It has 8 threads, but each thread is weak due to the architecture.
Also, a 2700k on Aria is only around £217 - bargain.
  #25
Old 09-08-12, 01:11 AM
OC3D Elite
My offering:
  #26
Old 09-08-12, 01:21 AM
seumasbeathan seumasbeathan is offline
Banned
That looks pretty good to me Couldn't personally suggest anything better
  #27
Old 09-08-12, 01:23 AM
OC3D Elite
Ooh, he has a case already.
Slightly updated. I don't know why you want wireless, you maniac, you, but there you are.
  #28
Old 09-08-12, 02:06 AM
OC3D Crew
I have that same wireless card Although I got sick of wireless, so I just ran a 100ft ethernet cable out my window down the side of the house into the window of the room where the router is... I thought that was the most efficient way of doing things.
  #29
Old 09-08-12, 02:39 AM
PEXON's Avatar
PEXON PEXON is offline
SleevingMaster
Send a message via Skype™ to PEXON
For 800 you should get a build with a 7970/670 easily. Why are people offering single 7770's for 800?!?
__________________
El Jefe of Sleeving
  #30
Old 09-08-12, 02:41 AM
CPMFW's Avatar
CPMFW CPMFW is offline
OC3D Elite
looking pretty good to me...
__________________
Tags
amd fx, gaming, project, rig, workstation
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
