Go Back   OC3D Forums > [OC3D] Hardware & Software > Software Section
Thread Tools Display Modes
  #11
Old 07-07-12, 07:07 AM
CPMFW's Avatar
CPMFW CPMFW is offline
OC3D Elite
maybe its a driver issue...
install the newest driver for your card and look from there
__________________
  #12
Old 30-10-12, 01:46 PM
neoguyver1 neoguyver1 is offline
Member
i would check what you memory is supposed to run at also volts and frequency and set it up in the bios.
__________________
i7 2600k, Hyper 612S, 8GB Patriot Viper Extreme 1866Mhz, Gigabyte Z68AP-D3, 7950 3gb oc sapphire, ZALMAN Z11, Antec TP-750.
  #13
Old 30-10-12, 02:08 PM
Ottovillem. Ottovillem. is offline
Newbie
Sorry i forgot to say that i found out what the problem was ... And it still amazes me. I got really mad and took my graphix out and i was going to return it but then i changed my mind and put it back and then it worked perfectly .... After that i moved and my cpu cooler broke so i took out my graphix again and after that my computer crashed again but then i remembered that my molexes were sitting diffrently when i took it out so i switched my molexes position so the 6/8 pin was inside and the usual 6 pin was outside. And then i found out that the problem was that the 6/8 pin was outside and the usual 6 pin was inside .... I still don't know why that thing caused me so many problems ...
  #14
Old 30-10-12, 02:21 PM
Member
Must have been how power was distributed across the cables, nice that you sorted it though.
__________________
Tags
crashes
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
