Go Back   OC3D Forums > [OC3D] Off Topic > Off Topic Chat > Rants
Thread Tools Display Modes
  #21
Old 31-07-08, 06:18 PM
PP Mguire PP Mguire is offline
OC3D Elite
I did a Google on it since ive never heard of it. Sounds pretty nice actualy. As you can see my Randall is my main amp cause i love fat tube sound. I just got it all fixed up. Bout 300 bucks worth of main tubes. Distortion 7 matched Groove Tubes. And all matched 12ax7 Groove Tube preamp. I get killer tone outa my amp with stock pickups from all my guitars.
I have the Vintage 30s in my Crate cabs actualy. I use these speakers because of their lower rating but greater ability to carry a guitar tone. Really what you want is a low watt great sounding speaker in your guitar cabs. Dont go for higher wattage rating. Because the faster you can break that distortion area the better gain reception youll get out of your speakers. In short, it will give you a sweeter gain without the nasty over distortion you dont want from over driving your amp (Or pedal) to hard. Im sure we all know what this sounds like. Crap. So say you have 4 30 watt speakers for a total peak output of 120watt per cab. The way i wire it would be for 8ohm since i run full stacks. If you plan to run half then wire for 4ohm. To hard to explain why, just trust me on that Your basic tube amp is 100watts (4 output tubes) so basicaly its really easy to break that barrier with any tube amp to get that "sweet spot".
My Randall cab for instance has 4 85watt Celestion 10" speakers and it even though it sounds great with my Peavey (160watt RMS) its not so great with my Randall cause i just cant get that tone i want out of it. Also, the way your speaker cabinet is made plays a big part in tone as well. The reason i prefer the Sunn cab with the Carvins is because its solid pine. Its alot heavier but i get more bottom end and umph from it. Thats becasue of the more solid wood. My Crate cabs are made from 3/4" Pressboard and the back is pine. Light weight and great for gigs (Use a PA to get bottom end that way) but other than that i prefer this Sunn now for recording and gigs where i need all my sound from the cab. Hope i helped learn somebody a few things.
  #22
Old 08-08-08, 12:07 PM
Zoot's Avatar
Zoot Zoot is offline
OC3D Elite
Nice gear you guys got there..
Here´s my 3 electrics
__________________
Desktop: AMD Ryzen 7 3700X | X570i Aorus | 32GB Corsair DDR4-3200MHz | RX 5700 XT | Aorus PCIe 4.0 1TB M.2 | Fractal Define Nano S
Home Server: AMD Ryzen 3 2200G | Asus Prime B450M-A | 16GB Crucial DDR4-2400MHz | 39TB | Fractal Design Define R5
HTPC: AMD Athlon 5350 | ASRock AM1H-ITX | 4GB Corsair DDR3-1333MHz | MiniBox M350
  #23
Old 09-08-08, 11:56 PM
OC3D Elite
Care to elaborate on what exactly they are? I love Ibanez guitars :rockon:
  #24
Old 12-08-08, 07:07 AM
freedom_12 freedom_12 is offline
Newbie
I think the red one is the exact same as mine, only mines in black.
Hot collection of guitars you got there.
  #25
Old 12-08-08, 07:23 AM
PV5150 PV5150 is offline
OC3D Elite
Nice collection of axes Zoot
Seeing as everyone else has added to this thread I'll try and get some of my gear up for you
__________________
Originally Posted by name='Jim'
"Jonathan 'Fatal1ty' Wendel may be 12-time world gaming champ, but how does he cope inside a 50c hot box sucking on a heavy load?":rocker::rocker:
  #26
Old 12-08-08, 07:29 AM
OC3D Elite
Uh oh here comes the 5150 *droooooooooooooool* I want one so bad
I think the middle guitar is an RG Prestige. Another *drooooool* But im quite content with my RG350dx. Once i get some new pickups in it, she'll be BEAST.
  #27
Old 12-08-08, 07:40 AM
Zoot's Avatar
OC3D Elite
Thanks guys! Ibanez guitars FTW!
The one on the right is a Prestige model, has a beautiful sound be it Wah, Distortion, Crunch or even clean. I use it mainly for rhythm playing and clean stuff.
The one in the centre is a regular RG with the Floyd Rose, this is the one I use for all my lead work. My playing style is sort of a hybrid between Eddie Van Halen and Joe Satriani, I just can´t stay away from the Floyd Rose!
The one on the right is a regular RG 7 string, which I mainly use for low clean stuff or any heavy riffage..
I´m just dying to ask, do you have a Peavey 5150?
__________________
  #28
Old 12-08-08, 07:49 AM
OC3D Elite
I do indeed mate. My forum username kinda gives it away lol
__________________
  #29
Old 12-08-08, 07:52 AM
Zoot's Avatar
OC3D Elite
I´m sure everyone would love to get a look at that!
__________________
  #30
Old 12-08-08, 08:29 AM
OC3D Elite
My friend has this guitar. Honestly i dont like it.
Do you have a "Floyd Rose" or "Ibanez Edge III" on that center guitar?
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
