Go Back   OC3D Forums > [OC3D] Customer Care Forums > Time To Live Customs
Thread Tools Display Modes
  #41
Old 21-04-15, 12:54 PM
cooperman's Avatar
cooperman cooperman is offline
OC3D Crew
Originally Posted by FredEx View Post
I see diagonal cutters, but a good pair of flush cutters is a must have. Trim anything you'd cut with diagonals, but flush cutters as named, cut flush. For example, cut a tie wrap and a flush cutter trims it so no sharp edge sticks out. I've used them for decades in component level circuit board repair to trim off excess leads. Note in the pic that the side with the cutting edge is flat and cuts things off flat.
I have allways used one of those too but i use them just for cuting cable ties
__________________
AMD Ryzen 5 2600,Patriot Viper 4 16GB 2x 8GB 3200 Ghz,Gigabyte B450M DS3H,Patriot BURST 480GB SSD x2, MSI 5700, Aerocool White Aero One Mini Eclipse, seasonic m12ii 620w,Deepcool gammaxx 400 v2.
  #42
Old 22-04-15, 06:25 AM
FredEx's Avatar
FredEx FredEx is offline
OC3D Crew
MUCH cheaper way to go than getting a Panduit tie wrap gun which is the best brand in my opinion. Somebody has money to burn, go for it.
__________________
R.I.P. Larry William Ross (Big Brother)16/6/1948 to 16/6/2013
R.I.P. Elizabeth Jane Durham Ross Curry (Mom) 9/6/25 to 30/7/2017
  #43
Old 23-04-15, 12:34 PM
voodoografix's Avatar
voodoografix voodoografix is offline
Member
Originally Posted by paulstung View Post
It was all my fault mate, a full on blonde moment, I have just had it returned with a cover letter saying " We have fully checked the unit, and all we had to do was, use the side power button, to switch it on " I completely forgot about the switch, I only ever use the main switch by the socket, I was that peeved that it wouldn't come on, I boxed it up and sent it off, without even a second thought of a power switch.
It has to be one, if not the biggest up I've ever made.
Mistakes will happen said the darlek climbing off the dustbin .
Edit:
Cutting wax I use a lot when drilling holes in cases . small laminate trimmer like the Makita for Perspex does a beautiful job .
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
